Old 12-28-2016, 05:18 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
LG Motorsports ZR28 20x10 / 20x11 Camaro Wheels
This sinister black beauty is ready to transform your Gen5 Camaro into the animal it was designed to be. These will greatly increase grip on your Camaro by increasing width of the wheel from a 8/9 to a 10/11" combo allowing much more tire to the ground for straight line and corning grip!
What it fits:
-2010-current V6 Camaro
-2010-current SS Camaro
-2013-current 1LE Camaro
-2013-current ZL1 Camaro
FAQ:
-Do I need new lug nuts? No, your stock nuts will work
-Will they accept my tire pressure sensors? Yes, you can use your stock or any stock replacement sensor
-Do they come with center caps? Yes, center caps are included
-Will they clear larger brakes? Those wanting to upgrade their brakes this will increase your clearance for BBKs
-Suggested tire sizes? Fronts should be a 275 or 285 width 20" and the rears a 305 or 315 width 20". Many SS customers can use their rears as fronts and just purchase rear tires
-What finish do they come in? Flat black only at this time as a no cost option.
-Feel free to ask about tire packages!
Size:
-20x10 front
-20x11 rear
SOLD IN SETS OF FOUR WHEELS
Ask about end of the year specials!
Anthony @ LG Motorsports is offline   Reply With Quote
Old 01-03-2017, 11:02 AM   #2
Special goes through tomorrow!
Old 01-11-2017, 02:43 PM   #3
RSCHRIS
RSCHRIS
RSCHRIS's Avatar
Drives: 2010 Camaro SS/RS
Man I wished these came in the 19 inch . I lowered my 2010 Camaro SS with 1in Eibach and yellow Koni's . I was running a 275-40-20 but now it's rubbing on the front struts, so I'm looking into a 19in rim and tire combo, with a larger size tire.
RSCHRIS is offline   Reply With Quote
Old 01-18-2017, 06:11 PM   #4
Wheel diameter shouldn't effect anything. Tire height will. If you have a rub issue it is either because the wheel offset is wrong, or the tire is to tall causing it to hit.
