Old 12-31-2016, 02:02 PM   #1
Blue70SS
Blue70SS's Avatar
3.08 & 3.23 gears for GM 9.5" 14 bolt differentials
Anybody have any info on how durable the 3.23 and 3.08 ring & pinion gears are for drag racing & mile runs? The LPE 9.5" diff uses GM 9.5" 14 bolt diff gears and 3.08 or 3.23 gears are options to break 200 mph without shifting into 6th gear and bogging. New 3.42 gears are readily available, but top out at 200.5 mph @6750 rpm.... so not ideal.
For 3.23 or 3.08 gears the only option is to find used gears..... but back to the point - are there known breakage concerns like Richmond had with early 4.xx gears?
Also, any experiences using this for drag racing? At mile hi elevation a 3.08 and 950ish RWHP would keep me from a 3-4 shift and I would think be quieter on the street.
....another question would be who has cracked an LPE diff and under what conditions (power/gearing/auto vs manual)
LPE Brotherhood
Old 01-02-2017, 10:52 AM   #2
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
Usually a 3.08 gear is a lot stronger than a 4.11 as an example.
Your right,not many 3.08 or 3.23 for a GM 9.5
2014 up Silverado some has 3.08 gears in the 12 bolt that is also a 9.5" ring gear setup.Don't know if they interchanged with the older GM 9.5".
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 01-02-2017, 02:20 PM   #3
Blue70SS
Blue70SS's Avatar
Yep, I spoke with American Axle and that's a new design... not compatible :(
LPE Brotherhood
Old 01-03-2017, 02:16 PM   #4
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
You will be exercising a 3-4 shift in the quarter with 3.08's
191mph in the Colorado mile. Will get one MPH faster going with the 3.23's.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 01-03-2017, 06:47 PM   #5
Blue70SS
Blue70SS's Avatar
Good point..... forgot to change to 28" tires for the 1/4 mile calcs - which would require 6950 rpm. 3.23s and a conservative 6500 shift would be 117.77 mph hitting 4th at 4542. Maybe get the 3.23s and have 3.08s shelfed for growing room later.
LPE Brotherhood
14 bolt, 3.08, 3.23, 3.42, 9.5
