Old 01-03-2017, 10:03 PM   #1
MileHigh13SS
Drives: 2013 Camaro SS Inferno Orange
Help identifying my 2013
Just purchased a 2013 SS. I'm trying to determine whether it has the 1le package. According to the VIN codes it is a SS2 with the 1le but it doesn't have the black hood, splitter or wing. How is that possible? Did they make 1les without those features? What gives? Help me out guys.
MileHigh13SS is offline   Reply With Quote
Old 01-03-2017, 10:08 PM   #2
Zezima
Zezima's Avatar
Drives: 2014 Camaro 2LT/RS
No they never made the 1LE without the black hood, splitter or wing
if your brakes are red then it's most likely a 1LE
edit: if you have leather seats, you DON'T have the 1LE package
Zezima is offline   Reply With Quote
Old 01-03-2017, 10:11 PM   #3
MileHigh13SS
Guess I'm reading the code wrong. According to one site there was a letter in the VIN that indicated the package.
Old 01-03-2017, 10:31 PM   #4
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
1LE is an option, not a model.
It would be in the RPO codes. The sticker is on the trunk floor, left side.
Nothing in the VIN indicates options.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 01-03-2017, 10:33 PM   #5
CamaroFred
CamaroFred's Avatar
1LE was available on 1SS and 2SS. Only restriction was the manual trans.
2011 1SS/RS LS3 CGM
Old 01-03-2017, 11:32 PM   #6
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Wow, this is entertaining. Let me get my popcorn and follow along.
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 01-04-2017, 12:26 AM   #7
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
look at the sticker under the carpet in the trunk. if you have a 1le it will have 1LE on the sticker.
The hoods were vinyl wrapped. Remove the wrap and its painted body color. The interiors had suede steering wheel, shifter and suede inserts. 10 spoke black wheels and red calipers.
JCunningham is offline   Reply With Quote
Old 01-04-2017, 08:29 AM   #8
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
Save some for me!
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 01-04-2017, 12:53 PM   #9
Camaro45rs
Camaro45rs's Avatar
Drives: 2012 Camaro RS 45th Aniv.
do you have the vin i could check my scanner
Camaro45rs is offline   Reply With Quote
Old 01-04-2017, 01:09 PM   #10
The camaro show
The camaro show's Avatar
Drives: 2015 camaro 2lt
all 1le's are ls3 engine do you have a l99 or ls3
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5
Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85.
The camaro show is offline   Reply With Quote
Old 01-04-2017, 01:24 PM   #11
HuJass
Drives: GM
Some people say the underhood portion of the steering column is painted white in a 1LE.
Don't know if that's true or not.
Your best bet is to look at the Service Parts Identifier label that's affixed to the trunk floor.
If it says 1LE on there, then it's a 1LE.
2015 Camaro 1LE
2009 Challenger R/T
2007 Solstice GXP
2004 Colorado ZQ8
2002 Trans Am WS6 Collector Edition
1999 Blazer
1994 Grand Prix SE B4U
HuJass is offline   Reply With Quote
Old 01-04-2017, 05:06 PM   #12
HDRDTD
I believe the size of the wheels/tires were different on a 1LE, and the rear differential had a 3.91 ratio gear.
