Old 01-05-2017, 01:17 AM   #1
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
Wiring schematic
Does anyone have the wiring schematic or know where theres a wiring schematic for the ignition system?
ticowarbird is offline   Reply With Quote
Old 01-05-2017, 05:46 AM   #2
1LEMan
1LEMan's Avatar
Drives: 2013 1LE Camaro RS/SS
Are you looking for the ignition coil power ckt or ? Which engine?
1LEMan is offline   Reply With Quote
Old 01-05-2017, 06:17 AM   #3
ticowarbird
BOHIC
Trying to figure out how to install a mom-off-on killswitch that'll allow remote start to still work for my 2010 L99.
Old 01-05-2017, 08:16 AM   #4
1LEMan
1LEMan's Avatar
Old 01-05-2017, 08:42 AM   #5
1LEMan
1LEMan's Avatar
It's probably easier to "cut" the starter trigger. I think it's a purple wire. Ill snap a pic of that schematic tonight unless someone else does.
Old 01-05-2017, 08:47 AM   #6
SnowyCamaro
SnowyCamaro's Avatar
Drives: 2013 Camaro ZL1, 2006 Chevy Equinox
Subscibed
SnowyCamaro is offline   Reply With Quote
Old 01-05-2017, 08:47 AM   #7
ticowarbird
BOHIC
Awesome! I appreciate it. Got nothing else to do overseas so figured I'd go to the junkyard and get some parts to play with.
Old 01-05-2017, 07:16 PM   #8
1LEMan
1LEMan's Avatar
Purple/wh wire.
Old 03-16-2023, 08:36 PM   #9
Notthis5gen
Notthis5gen's Avatar
Drives: 2013 Camaro 2SS
Sup brotha , where did you tap into to install this kill switch ? I’m trying to do the same on my 13
Notthis5gen is offline   Reply With Quote
Old 10-03-2023, 05:05 AM   #10
ticowarbird
BOHIC
Actuall Never got around to it but started looking again. Gotta do the trunk killswitch for NHRA and might put one in the cabin somewhere.
What else can I do to my Camaro?
Old 09-19-2024, 04:36 AM   #11
djamphi555
Drives: Camaro 2010
Where is that diode between x1 and x3 in the fuse block after the 30amp starting fuse?
djamphi555 is offline   Reply With Quote
