Old 01-05-2017, 06:13 PM   #1
ZEV1L ONE
ZEV1L ONE's Avatar
Drives: 2015 AGM ZL1 (6M)
First Round!
Here is the list below, I'm about to pull the trigger from JDP
The whole idea of this first stage of parts is NOT to tune it due to the factory warranty still having a little left on it.
Let me know if you think I'm missing anything.
ZEV1L ONE is offline   Reply With Quote
Old 01-05-2017, 06:25 PM   #2
crazydave
crazydave's Avatar
Drives: 2013 Camaro ZL1 M6
I would ditch the ported TB, no real performance gains there. I would replace it with the D3 or other coolant reservoir. I am assuming you already have a CAI, if not that's a must.
I ran a 5% OD, Rotofab CAI and larger HX for a while and the car ran great.
2013 ZL1 CRT M6
__________________________________________________ ____________________________________
Current Mods: Rotofab CAI, Big Gulp, and Res. ATI Superdamper and 10" Lower, DSX FF Sensor, DSX Aux Fuel Pump, ID850s, Kooks 1 7/8" Headers, Forced Induction Interchiller, McLeod RTX Twin disk. DSX Tuned. Running on 20" MT ET Street SS on stock wheels for the strip.
Best 1/4 mile to date:10.81 @130.43 mph w/ 1.61 60'
Just added: Jokerz Stage II blower port and FI Interchillers blower lid spacer.
crazydave is offline   Reply With Quote
Old 01-05-2017, 06:30 PM   #3
ZEV1L ONE
ZEV1L ONE's Avatar
Got the reservoir in there already and Intake with the big gulp kit. I heard there is a noticeable increase in HP from that throttle body, not to mention better response. Is that some oceanfront property in Arizona that I've been sold?
Old 01-05-2017, 06:34 PM   #4
Buckley12
Drives: 2013 zl1
I bought the throttle body, car felt a little more responsive but I don't know if it had any positive or negative power gains
Buckley12 is offline   Reply With Quote
Old 01-05-2017, 06:37 PM   #5
crazydave
crazydave's Avatar
Originally Posted by ZEV1L ONE View Post
Got the reservoir in there already. I have heard there is a noticeable increase in HP from that throttle body, not to mention better response. Is that some oceanfront property in Arizona that I've been sold?
I tried it, wish i hadn't. I didn't feel any difference with it power wise other that it making the car feel overly sensitive during light throttle applications, which made launching the car inconsistent at the track. (I run alot of 1/4 mile passes, if there was a gain i would have noticed it). I took it off and sold it after a few months. They don't mess with the blade size, so the smallest part of the TB is still the same size.
Save that money for when you get to the next stage and just get a 90mm or larger. They are like 160 thermostat, some people swear that the it helps them, others swear they don't. I am adverse to spending money when i cannot prove an improvement.
2013 ZL1 CRT M6
Old 01-05-2017, 06:41 PM   #6
ZEV1L ONE
ZEV1L ONE's Avatar
I hear that. Thanks for the input!
Old 01-05-2017, 07:07 PM   #7
mikey1107
mikey1107's Avatar
Drives: 2017 SS
Is that heat exchanger really that much better than an Afco at more than double the price?
2017 SW SS
mikey1107 is offline   Reply With Quote
Old 01-05-2017, 07:09 PM   #8
Z/28Dan
Z/28Dan's Avatar
Drives: 2023 1SS 1LE Vivid Orange
That's true. There are less expensive solutions.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan
Z/28Dan is offline   Reply With Quote
Old 01-05-2017, 07:13 PM   #9
crazydave
crazydave's Avatar
I agree, that is a bit pricey. Besides the AFCO, check out the Ron Davis. Both would be more than adequate and leave you some room to grow.
2013 ZL1 CRT M6
Old 01-05-2017, 07:34 PM   #10
mikey1107
mikey1107's Avatar
Drives: 2017 SS
I see now, the $1100 includes the D3 reservoir also. Still pricey but good quality stuff.
2017 SW SS
Old 01-05-2017, 08:23 PM   #11
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
No gain with the TB in you setup.. You will need to move more air with Cam, and bigger pulley before you see it's effects. I think Ted Jannety has a write up on it somewhere.
ZMEnow is offline   Reply With Quote
Old 01-05-2017, 08:32 PM   #12
ZMEnow
The Afco unit seems suited more for a drag racer so you could run the fans in the pits, otherwise I don't see much benefit over any of these. For a road racer I'd recommend the Ron Davis unit as it is not so big as to potentially block air flow to the radiator. I do not have any dyno comparisons, but all of the heat exchangers listed have very high quality cores and will greatly help with IATs.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
http://www.camaro5.com/forums/showthread.php?t=357226
Old 01-05-2017, 10:08 PM   #13
atn
atn's Avatar
Drives: 2012 ZL1 Silver Ice
Anyone heard anything new on the Catch Can warranty issue? Last I read GM was voiding warranties if one was installed. I have one but have not put it in because I have a GM extended warranty till 2019.
atn is offline   Reply With Quote
Old 01-06-2017, 12:12 AM   #14
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
Ive seen that D3 HX for 800 new idk why you paying 300 more
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
