Old 01-07-2017, 02:03 PM   #1
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
Catch can hooked up wrong???
Hi all,
So, I went to drain my catch can after around 3,000 miles in a year. And.... to my supprise.......nothing. Not a drop! I have a line coming from the back drivers side valve cover to the can, then a line from can to under the throttle body. Am I missing something here? Help please.....
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 01-07-2017, 07:01 PM   #2
G701LE
G701LE's Avatar
No one running a catch can on an L99?
Old 01-07-2017, 07:15 PM   #3
BigRed585Lbs
Drives: Sierra and Tahoe
Link to "Search for L99 catch can hook-up" doesn't link back to thread. You'll have to do it on your own.
BigRed585Lbs is offline   Reply With Quote
Old 01-07-2017, 07:22 PM   #4
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I wish I could be more help. I have a 2015 L99 and the pcv is on the -Passenger- side of the engine. I don't have a catch can but that's where I spliced the line for the CAI.
Moto-Mojo is offline   Reply With Quote
Old 01-07-2017, 07:46 PM   #5
G701LE
G701LE's Avatar
Originally Posted by BigRed585Lbs View Post
That doesn't work.....
Old 01-07-2017, 07:51 PM   #6
G701LE
G701LE's Avatar
I hooked it up per the instructions. I don't know. Weird how there is NO oil in it.
Old 01-07-2017, 07:56 PM   #7
Moto-Mojo
Moto-Mojo's Avatar
Do you put yer foot in it very often?
Old 01-07-2017, 08:08 PM   #8
G701LE
G701LE's Avatar
I don't rag on it. But, I do drive spirited when I do drive it. I only put about 2,500 miles on it in a year.
Old 01-07-2017, 08:37 PM   #9
fastjohnny
fastjohnny's Avatar
On your drain open the valve, if there is vacume when you put your finger on it, it is hooked up correctly, if not you have it hooked up wrong, if I remember correctly
Sent from my Nexus 10 using Tapatalk
fastjohnny is offline   Reply With Quote
Old 01-07-2017, 09:08 PM   #10
Brian22
Drives: 2015 camaro ss
AFQjCNHBgMnJ83F9hYT8qUVePGgxmb43DA&sig2=S2MrC2IDPc P8uUm6ahdbuw
Brian22 is offline   Reply With Quote
Old 01-07-2017, 09:09 PM   #11
bayarea408
bayarea408's Avatar
Drives: T
The way mine is hooked up is,
there is a valve cover nipple on the passenger side valve cover towards the front of the car sort of near the oil fill cap it comes out a bit sideways. that line goes to my Catch can and a line from my catch can goes to the nipple feed on the intake manifold.
The fitting on the driver side rear i have hooked up to a breather filter separately.
This is how i was instructed by Mighty Mouse to run it since L99 does not have a breather pipe coming from the Intake valley plate, under the intake manifold.
This has worked for me i see a sight glass and can see oil.
bayarea408 is offline   Reply With Quote
Old 01-07-2017, 09:11 PM   #12
Brian22
Look up elite engineering instructions for l99. That's what I used to install.
Old 01-07-2017, 10:13 PM   #13
G701LE
G701LE's Avatar
Looks like I hooked it up right.......
Old 01-07-2017, 11:36 PM   #14
Brian22
And you have one of the hoses hooked up behind the intake manifold?
