![]() Drives: 2010 camaro Join Date: May 2013
Front subwoofers with no sound this cold morning
Anyone else have this happen? Wasn't sure if a fuse blew or what, but this morning, it was cold (it's been colder), and absolutely no sound came out of the front subwoofers until the car had been on for 30 minutes.
Is there even a fuse specifically for them? The other speakers worked okay from what I could tell. |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
The doors have a 6.5" woofer cone inside each and there is no fuse for them as they are wired directly to the amplifier. A speaker not producing sound can only be three possibilities if system power is on;
The term "subwoofer" is indicative of an independent driver mounted in a dedicated enclosure capable of reproducing a 20hz (or lower) note. Generally requiring an 8" round driver at a minimum.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
There is no front sub.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
You say there's no fuse for them, but wouldn't there be for the amplifier?
I always thought they were subs with how much bass they put out. Like not great subs, but subs lol. |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
some call this the front sub...its just a speaker
#6 |
COTW 5/06/2013
these are the others..
