Old 01-14-2017, 04:17 PM   #1
Ranger175
Drives: 2013 Camaro ZL1, M6
Question BMR 1.25" lowering springs ZL1
I have a 2013 M6 ZL1 coup. I've been reading older posts about re-indexing the bushings after installing lowering springs. It's advertised to reindex the bushings for the V8 models. Does the same apply for the ZL1? I just picked up BMR 1.25" springs. The current directions call for re-indexing the rear bushings only, but older threads by members on Camaro5 state that the front bushings should be done too. Did something change from then to now to where only the rears need to be done? I emailed BMR and they said that the fronts should't have to be done. I'm a newbie and just trying to make sure I install them right and I figured this forum would be a good place to get some good info. Lastly, does anyone know if the torque specs for the bushings are the same for the standard V8 models and ZL1 or does the ZL1 have different specs? Thinks for your help gents.
93 tuned, 736 rwhp, 691 rwtq. FBO HCI, 2.5/9.5 pulleys, PCM’s of NC ‘ZL Win’ Cam, stock crank, Wiseco pistons, Callie’s rods, King main/Rod bearings, 1050x injectors, Elite E2 catch can, Rotofab CAI, Johnson 2110 lifters, AI 280cc p+p heads, ported 90mm TB, Lingenfelter HX, D3 reservoir, MSD BAP, BTR valve train, head/main studs, Melling oil pump, Straib trunnions, C5r timing chain, Kooks 1 7/8 LT’s w/ cat delete.
Ranger175 is offline   Reply With Quote
Old 01-17-2017, 08:45 AM   #2
GONMAD510
Drives: 2013 ZL1 M6
I am running the BMR 1.25" lowering springs. I only re-indexed the rears per the instructions. I have not had and issues with them.
GONMAD510 is offline   Reply With Quote
Old 03-19-2017, 12:41 PM   #3
bill1969camaro
Drives: 1969 camaro
How much do these actually lower the ZL1's Thanks.
bill1969camaro is offline   Reply With Quote
Old 03-20-2017, 10:52 AM   #4
GONMAD510
Drives: 2013 ZL1 M6
I have these springs on my car and it did lower it a little over an inch.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
Old 03-29-2017, 09:08 AM   #5
bill1969camaro
Drives: 1969 camaro
Thank's for the info.
2013 zl1, bmr, lowering springs, zl1, zl1 lowering springs
