Old 01-16-2017, 04:21 PM   #1
onegoofydad
Drives: 2014 Camaro 2SS
160 Degree Thermostat
When is it a good time to drop to a 160 degree thermostat? Is it a required change at some point in your MOD lineup list. I assume most FI guys drop down, but any advantage to dropping down when your NA?
Also any adjustments on the computer need to be made when swapping to a 160?
2014 Black/Black Camaro 2SS RS L99, CAI Intake, Speed Engineering LTH. Jannetty Tuned.
onegoofydad is offline   Reply With Quote
Old 01-16-2017, 04:49 PM   #2
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
160 degree thermostat was included as part of my 650 HP Lingenfelter build. When I dropped in an LSX-376, 765 HP build, from a local Corvette specialist, was told not to, not needed. Can't remember specifics but I thought it had something to do with engine specs/design.
Someone who knows alot more about these engines should give you a better answer than mine. But there was 2 different opinions by 2 reputable builders.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 01-16-2017, 06:06 PM   #3
Gunmetal Speedster
Gunmetal Speedster's Avatar
Drives: Savitar; The 500rwhp N/A Monster!
Been wanting to know this as well.
*SOLD*504HP/433TQ | Night Fury cammed • Cold Air Inductions intake • Bo White ported TB • Speed Engineering 1 7/8 longtubes • NPP catback • QTP low profile cutouts • Powerbond 25% UDP • 3.73 gears • JRE scoop • ZL1 grille • R1 Concepts drilled/slotted rotors • built/tuned by Weapon X Motorsports
Gunmetal Speedster is offline   Reply With Quote
Old 01-16-2017, 07:45 PM   #4
TX_ED_SS
TX_ED_SS's Avatar
Drives: 2010 2SS/RS Inferno Orange
No need to put in a 160 thermostat. Check out a thread under the V8 bolt on section. Just search for 160 Degree Thermostat. There is some really good info in there.
http://www.camaro5.com/forums/showth...ree+thermostat
U.S. Army Retired
TX_ED_SS is offline   Reply With Quote
Old 01-16-2017, 10:31 PM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
when you're living in the middle east and the temps are 120F. 160 tstat is a tuner snake oil mod
JCunningham is offline   Reply With Quote
Old 01-17-2017, 12:04 AM   #6
jcaligood
jcaligood's Avatar
Drives: '18 SS 1LE
I believe Ted has chimed in on this stating the engines are best running at ~200F, no need.
jcaligood is offline   Reply With Quote
Old 01-18-2017, 02:17 AM   #7
InFiD3ViL
InFiD3ViL's Avatar
Makes me wonder what temp the ECU starts to pull timing or what the table looks like.
I know for certain that my car pulls harder when coolant is at 195 than when it is at 215....not that it gets that high very often.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4, 7Ί overlap) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP 1-7/8" long tube headers (W/Catless Off-road Pipes), Corsa Xtreme 3" Catback, GPI Ported/Rod Mod Intake, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160Ί thermostat - Megan Racing adjustable coilovers (lowered 1.75"), MRR M017 10/11" wheels-Tuned by Ryan @ GPI
Old 01-18-2017, 03:36 AM   #8
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
When carburetors were used coolant was circulated through the intake manifold to keep the gasoline vaporized as it traveled to the intake valves.
That would, of course, heat the air entering the cylinders, making it less dense but more drivable on cold days.
With fuel injection there is no need to heat the intake manifold so coolant no longer runs through it. Thus a lower temperature thermostat doesn't have any effect on the engine, but will cause you to put on your hat and gloves and won't keep the windows defrosted when it is very cold out. (keep your mouth closed when you breathe)
I don't believe the ECU changes timing due to temperature, the MAF on your intake signals the ECU as to air density and then the fuel is adjusted to be correct. Then the O2 sensors let the ECU know if the mix isn't perfect and the ECU adjusts accordingly (short term fuel trim).
Only if the knock sensors are activated will the ECU change the timing. And on the V8s it isn't very quick to try to return to the most advanced timing possible. Thus the fuse pull to reset.
More than likely the reason your car pulls harder when the coolant is at a lower temperature is because the outside air is at a lower temperature, and thus denser, so as more oxygen is ingested more fuel is added, thus more power. That is the MAF signaling the ECU. And, as noted above, the O2 sensors have the final say to the duration of the opening of the fuel injectors.
It is rocket science.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 01-18-2017, 04:27 AM   #9
Aaron0731
Drives: 2010 2SS/RS L99
I know colder thermostats can be used in vehicles with superhargers to some benefit. Not sure about NA motors.
Aaron0731 is offline   Reply With Quote
Old 01-18-2017, 03:39 PM   #10
CamaroFred
CamaroFred's Avatar
Originally Posted by klaatu barada nikto View Post
I run 160* SLP stats in our '15 SS and '09 Vette. Both cars run 170-180* cruising with no timing being pulled which is exactly where i want them.
Strong power plus gas mileage didn't change.
Works for me.
The SS and vette were retarding spark with the factory thermostats?
I thought the millions of super computer hours in the design would have noticed that.
2011 1SS/RS LS3 CGM
