Old 01-16-2017, 05:52 PM   #1
wally mayfield
wally mayfield's Avatar
Drives: 2013 2SS 6M
not happy with the clay bar...
with removing water spots on my black Camaro..
I have the Meguiar's smooth surface clay kit..it looks better but I still can see the water spots..should I continue with the clay bar and follow up with something like Adams paint finishing polish and or the Paint correction polish both of which I have??
Or?
Strut tower brace(GM), CAI, Blade Spoiler, ZL1 wheels and tires, Heritage grill, Dual mode exhaust, and thats it, no more..except for the lowering springs..Ok Hotchkis springs were delivered today, thats it..
wally mayfield is offline   Reply With Quote
Old 01-16-2017, 06:11 PM   #2
BeastMode
Drives: 2011 SGM 1SS/RS M6
Clay bar can remove contaminants on the paint. Water spots can actually be etching in the clear coat due to acidic rain or other minerals. Whatever a clay bar doesnt take out, a polish certainly would.
I dont have experience with either of those compounds, but since Adam's is top notch, I assume they would take care of the job.
Current: 2011 SGM Camaro 1SS/RS M6 - CAI Cold Air Kit, Janetty Tuned
BeastMode is offline   Reply With Quote
Old 01-16-2017, 06:47 PM   #3
wally mayfield
Drives: 2013 2SS 6M
Ha!! I looked at the side of the box the stuff came in and it says to use their "Ultimate compound " to get rid of water spots..
thanks
Old 01-17-2017, 05:54 AM   #4
BRZN
BRZN's Avatar
Drives: 2012 1LT
After claying, polish.
It all depends on what your water spots are. Are they mineral deposits sitting on top of the paint or are they little craters etched into the paint? If they're etched into the paint you'll need to remove all the surrounding clear to be even with the bottom of the etching to make them completely go away. Try wiping with distilled white vinegar, the acidic nature of the vinegar will help dissolve the minerals the clay didn't remove. If the vinegar wipe didn't change the appearance of the water spots you'll need to polish. Meguiar's Ultimate Compound, or Adam's Paint Correcting Polish would be good choices of polishes. The attached link shows all three of Adam's choices, From his new Heavy Correcting Compound, to his Paint Correcting Polish, to his Paint Finishing Polish. You'd want to start with the least aggressive first to see how that works for you.
This link my help with identification:
http://www.adamsforums.com/topic/158...pots/?p=245634
BRZN is offline   Reply With Quote
Old 01-17-2017, 02:00 PM   #5
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Here is a good thread which will show you what type of water spots you have, and how to remove them.
http://www.autogeekonline.net/forum/...-type-iii.html
Your Adams products should work fine if you have Type II water spots.
The important thing is to find out why your getting these spots.
Do you park near sprinklers?
Do you wash/dry the car in direct sunlight?
Do you rinse the car without drying it?
Is the rainwater acidic where you live?
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 01-17-2017, 05:34 PM   #6
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Or?
Once you have clayed our Correcting Polish & Finishing Polish should do the trick and if they are etched in too deep the polishing will certainly lessen them.
Just remember once you remove them, keep a good coat of wax or sealant to help prevent them in the future.
Old 01-17-2017, 09:33 PM   #7
s/c ss
s/c ss's Avatar
Drives: 13 ZL1, 10 Silverado LTZ, Chopper
Can the correcting polish and the finish polish be applied by Hand?
s/c ss is offline   Reply With Quote
Old 01-18-2017, 06:26 AM   #8
BRZN
BRZN's Avatar
Drives: 2012 1LT
Yes, but they won't perform by hand like they will on a machine. The machines run at Oscillations per Minute (OPM) in the 1,000+ range. You'll not get anywhere close to that speed by hand. He does have a hand polish, Revive Hand Polish, but don't expect miracles by hand.
Old 01-18-2017, 02:39 PM   #9
wally mayfield
Drives: 2013 2SS 6M
I have your buffing pads as well, which one should i use to use the "Paint correcting polish"?
Old 01-18-2017, 02:40 PM   #10
wally mayfield
Drives: 2013 2SS 6M
I told my girlfriend that same thing...
Old 01-18-2017, 03:28 PM   #11
BRZN
BRZN's Avatar
Drives: 2012 1LT
Adam color coordinates his pads and polishes.
Blue pad with his Blue Heavy Correcting Compound
Orange pad with his Orange Paint Correcting Polish
White pad with his White Paint Finishing Polish
Old 01-18-2017, 04:32 PM   #12
gringo
gringo's Avatar
Drives: Camaro V6
Use white distilled vinegar. Works like a charm for me!
gringo is offline   Reply With Quote
Old 01-18-2017, 11:52 PM   #13
wally mayfield
Drives: 2013 2SS 6M
not for me...I live in the eastern high sierra the water is really hard.
