Old 01-18-2017, 08:47 AM   #1
Rich S
Drives: corvette
Ordering a new 1LE
Just want to make sure I got everything correct. This will have the leather seats correct? Also, what is up with the circled item. Car is black, why is this not the same. Any help would be appreciated!
Rich S is offline   Reply With Quote
Old 01-18-2017, 09:14 AM   #2
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I am not the expert, but a Gen 5 1SS does not have leather, and also when you ordered a 1LE on a gen 5, the code was 1LE. I am not so sure what the situation is with the Gen 6, but I am not at all confident that you have ordered a 1LE (plus you seem to have ordered a splitter, which is part of the 1LE package....at least on a GEN 5). You might have better answers on Camaro6.
gajagfan is offline   Reply With Quote
Old 01-18-2017, 09:30 AM   #3
BeMe
Drives: '14 1LE
"TRIM: H1T-Cloth, Jet Black, Interior Trim"
BeMe is offline   Reply With Quote
Old 01-18-2017, 09:31 AM   #4
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
I'm not an expert, but if the build sheet says cloth seats twice.... It won't come with leather. Also, as stated above, camaro6 would be a better place to post this. Maybe the mods will move it for you.
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 01-18-2017, 10:14 AM   #5
Rich S
Drives: corvette
oops! Sorry about that. Mods please delete. I did not realize I was in the wrong forum
Old 01-18-2017, 10:53 AM   #6
CLEAN
CLEAN's Avatar
Drives: '19 Stingray '22 MB GLC 300
No need. Your order is fine. The 6th gen 1LE comes w/ the leather/suede seats standard as part of the 1LE package, and the rear seats will be the standard leather seats, not cloth. The front splitter is not black, but in fact a dark grey to match the rear spoiler and wheels. I didn't realize it was Nightfall Grey, but it's fine. Order is fine.
"Ever since we got the Camaro, everything seems better"
-My 6 year old daughter
CLEAN is offline   Reply With Quote
Old 01-18-2017, 11:16 AM   #7
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
A1Y is the 1LE performance package, which you have ordered for $6500.
http://gmauthority.com/blog/wp-conte...ly-29-2016.pdf
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 01-18-2017, 01:00 PM   #8
14Black1LESS
14Black1LESS's Avatar
Drives: 2014 2SS/RS/1LE
I could be wrong but I thought I saw somewhere that all the Gen 6 1LE's come with Recaro's. I don't see Recaro's on there. As mentioned above you might want to post this on the Camaro6 forums, they would be able to help you a lot more.
Edit: Never mind, after finding the code in the link above I see it now.
14Black1LESS is offline   Reply With Quote
Old 01-18-2017, 01:27 PM   #9
gajagfan
gajagfan's Avatar
One thing that seems odd is that parts of the 1LE package are listed as separate options, like the hood wrap. Seems like an odd way to do it.
Old 01-18-2017, 10:02 PM   #10
Mnhdrider
Drives: 15 black 2SSRS1LE
Here is the GM list
January 18, 2017
Both LT and SS models have the leather inserts with Ricaro seats with the 1LE package.
Vehicle Information
VIN: 1G1FE1R70H0174463 Model: 1AJ37-2017 CAMARO
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Vehicle Build
Model: 1AJ37-2017 CAMARO Order Number: TVZZGZ
Gross Vehicle Weight: 2,051 Build Date: 12/12/2016
Build Plant: 0
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
1SS - BASE EQUIPMENT PACKAGE 1SZ - OPTION PACKAGE DISCOUNT
4AA - INTERIOR TRIM 5A7 - SPARE WHEEL-NONE
6X1 - COMPONENT 7X1 - COMPONENT
8GW - COMPONENT RR LH 9GW - COMPONENT RR RH
9L3 - SPARE TIRE - NONE A1Y - SS 1LE TRACK PERFORMANCE PKG: * WHEELS, 20" FORGED ALUMINUM * MAGNETIC RIDE CONTROL * RECARO PERFORMANCE FRONT BUCKET SEATS * DIFFERENTIAL, ELECTRONIC LIMITED SLIP * EXHAUST,DUAL MODE PERFORMANCE * BREMBO PERFORMANCE BRAKES, RED CALIPERS * HEAD-UP DISPLAY * BLADE SPOILER, SATIN BLACK * HOOD WRAP, SATIN BLACK * FRONT SPLITTER, SATIN BLACK * SUEDED SHIFT KNOB & STEERING WHEEL * SUMMER ONLY TIRES (DELETES RUN FLAT TIRES AND ADDS TIRE SEALANT AND INFLATOR KIT)
AKQ - 6-WAY POWER PASSENGER SEAT AL0 - AIRBAG SENSING SYSTEM , PASSENGER
AM7 - REAR SEAT, FOLDING AQJ - RECARO PERFORMANCE FRONT BUCKET SEATS
AT8 - REAR CHILD SEAT LATCH SYSTEM ATH - KEYLESS OPEN AND START
AV3 - 8-WAY POWER DRIVER SEAT AXJ - PASSENGER CAR
AYG - AIR BAGS, DRIVER AND FRONT PASSENGER DUAL-STAGE FRONTAL, THORAX SIDE-IMPACT, KNEE AND HEAD CURTAIN SIDE-IMPACT FOR FRONT AND REAR POSITIONS B34 - FLOOR MATS, FRONT
C68 - AIR CONDITIONING, SINGLE ZONE AUTOMATIC D31 - MIRROR, MANUAL INSIDE RR VIEW
D5S - SATIN BLACK BLADE SPOILER DCP - PROCESSING DIRECTIONS & CONNECTIONS SERVICE PACKAGE
DG7 - POWER OUTSIDE ADJUSTABLE MIRRORS DNS - DEALER INSTALLED INDICATOR
DSM - HOOD WRAP, SATIN BLACK EF7 - COUNTRY UNITED STATE OF AMERICA
F55 - MAGNETIC RIDE CONTROL FE4 - SPECIAL RIDE & HANDLING
FE9 - 50-STATE EMISSIONS FJW - VEHICLE FUEL GASOLINE
FTJ - FRONT SPLITTER, BODY COLOR G96 - DIFFERENTIAL, ELECTRONIC LIMITED SLIP
GB8 - MOSAIC BLACK METALLIC GT4 - REAR AXLE, 3.73 RATIO
H1T - JET BLACK I17 - ENGINEERING YEAR 2017
IO5 - CHEVROLET MYLINK AUDIO SYSTEM 8" DIAGONAL COLOR TOUCHSCREEN SELECT BLUETOOTH STREAMING, APPLE CARPLAY CAPABILITY PROVIDED BY APPLE. AVAILABLE WITH COMPATIBLE SMARTPHONES J6M - BREMBO CALIPERS, RED
J77 - BRAKE, ELECTRONIC PARKING KC4 - ENGINE OIL COOLER
KD1 - COOLER, TRANSMISSION OIL KNR - COOLER, REAR DIFFERENTIAL
KRV - REFRIGERANT KS9 - SUEDE SHIFT KNOB
KTI - TIRE SEALANT & INFLATOR KIT IN PLACE OF SPARE TIRE LAL - LANSING PLANT CODE
LT1 - ENGINE, 6.2L V8 DI MAH - MARKETING AREA NORTH AMERICA
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
N26 - SUEDE STEERING WHEEL NPP - EXHAUST, DUAL MODE PERFORMANCE
NTB - EMISSION SYSTEM NV9 - PWR STEERING, ELECTRIC
R0G - TIRES, 285/30R20 FRONT AND 305/30R20 REAR, BLACKWALL, SUMMER ONLY R7I - ONSTAR 3 MONTH TRIAL DELIVERED AFTER 12/31/16
R8J - LGR-ID CAMARO COUPE MODELS R9N - VOMS PROCESSING OPTION
RSK - WHEELS, 20" ALUMINUM SBF - SAFETY BELTS
SLM - STOCK ORDERS T3S - DAYTIME RUNNING LAMPS
T4F - HEADLAMPS, HID WITH LED SIGNATURE T61 - DAYTIME RUNNING LIGHTS
TD2 - SHIP THRU - GROUND EFFECTS TDM - TEEN DRIVER
U2K - XM RADIO + SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUSXM AFTER 12 MTHS U77 - ANTENNA, ROOF MOUNTED
U80 - COMPASS DISPLAY UE1 - ONSTAR(R)
UHS - DRIVER INFORMATION CENTER, 8" DIAGONAL MULTI-COLOR DISPLAY UMN - SPEEDOMETER
UPG - BLUETOOTH FOR PHONE UQ3 - AUDIO SYSTEM
UQT - PERFORMANCE DATA AND VIDEO RECORDER UST - USB PORTS
UV6 - HEAD-UP DISPLAY UVC - REAR VISION CAMERA
V03 - COOLING SYSTEM, EXTRA CAPACITY V18 - COOLER, ENGINE COOLANT
V8D - VEHICLE STATEMENT US VK3 - FRONT LICENSE PLATE BRACKET
VRG - VAA/COMPONENT REL COCKPIT VRH - VAA/COMPONENT REL STEERING COLUMN
VRJ - VAA/COMPONENT REL POWERTRAIN DRESS VRK - VAA/COMPONENT REL ROOF TRIM
VRL - VAA/COMPONENT REL FRONT HORIZONTAL SUSPENSION VRM - VAA/COMPONENT REL FRONT VERTICAL SUSPENSION
VRN - VAA/COMPONENT REL REAR SUSPENSION VRR - COMPONENT
VT7 - OWNERS MANUAL VV4 - 4G LTE WI-FI(R) HOTSPOT WITH LIMITED DATA TRIAL AND MORE. (SUBJECT TO TERMS SEE ONSTAR.COM)
WMH - VIN MODEL YEAR 2017 XL8 - FREQUENCIES RATING 433 MHZ
Added Option Codes
Vehicle has no current record of SAIO codes.
For this vehicle:
→ View Vehicle Summary
→ Service Contract
→ Branded Title
→ Warranty Block
→ View Vehicle Build
→ View Vehicle Component Summary
→ View Vehicle Transaction History Detail
→ View Vehicle Delivery Information
→ Investigate Major Assembly History
Global Warranty Management: Site Map
Privacy Policy Terms of Use © 2005 General Motors. All rights reserved.
Mnhdrider is offline   Reply With Quote
Old 01-19-2017, 08:01 AM   #11
SSmitch
SSmitch's Avatar
Drives: 14 2SS/RS/1LE
2017 A1Y Option
A1Y
SS 1LE Performance Package, includes (J6M) Brembo Red,
6-piston front monobloc calipers, 4-piston rear calipers, 2-piece
rotors, performance, 4-wheel antilock, 4-wheel disc brakes, (G96)
electronic limited slip differential, (NPP) dual-mode performance
exhaust, (F55) Magnetic Ride Control, (FE4) performance
suspension, (FTJ) Satin Black front splitter, (DSM) Satin Black
hood wrap, (D5S) Satin Black rear blade spoiler, (R0G)
285/30R20 front and 305/30R20 rear, blackwall, summer-only
tires, (RSK) 20" x 10" front and 20" x 11" rear Satin Graphite
forged aluminum wheels, (AQJ) RECARO performance front
bucket seats, (UV6) Head-Up Display, (N26) sueded-wrapped,
flat-bottom steering wheel and (KS9) sueded-wrapped shift knob
1 - Requires (H1T) Jet Black interior trim and (MN6) 6-speed
manual transmission. Not available with (CF5) power sunroof; the
following stripes: BO3, C2U, DUV, DW7, DW8; and the following
LPOs: 56F, 56H, 56K, 5K2, 5LQ, 5V5, 5VM, 5ZB, 5ZU, RN2, RXJ,
RY2, RZ3, RZ9, S0J, SB7, SFA, SFD, SG3, SHR, SNG, SNH, VPW,
VUP, VW9, WGL
6/17/22 UPDATE:
SOLD W/4900 Miles to Berger Chevrolet
Grand Rapids, MI
2014 Camaro 2SS/RS/1LE
Livernois Motorsports:
Ported Heads, TB & Intake.
2 R Max Cam (W/upgraded dual valve springs & pushrods)
Kooks 1 7/8" SS Headers, HF Cats & NPP Exhaust
MSD Wire Set/Roto-Fab CAI
Elite Oil Catch Can/GM Oil Catch Can (Clean Side)
Custom Tune 93 Octane
500 WHP 453 WTQ
Sound Bite:https://www.youtube.com/watch?v=CGBUYF1Ce9Q
Dyno Run:https://www.youtube.com/watch?v=BPE6DrtnVfo
SSmitch is offline   Reply With Quote
