Old 01-21-2017, 02:28 PM   #1
--camaro--
Drives: 2011 1SS/RS LS3 SIM w/black strips
URGENT QUESTION on stagnant oil
We are on our way to pick up a 2015 Z28. It is brand-new off the lot and only has about 30 miles on the odometer. What are y'all's opinions on the condition of the oil being it's probably sat in the car for about a year if not more? Should we have to worry about any of the additives being broken down or not?
--camaro-- is offline   Reply With Quote
Old 01-21-2017, 02:37 PM   #2
Fastduo
Drives: 2015 Z28 Silver w/AC
I would be more worried about the filters sitting in the liquid for that lenght of time. Request a pre delivery service.
Fastduo is offline   Reply With Quote
Old 01-21-2017, 02:51 PM   #3
O.F.
O.F.'s Avatar
Drives: 2015 BLK/BLK 2SS/RS MN6
If it were mine, I would take it home and change it myself to see what it looks like. Thirty miles a quarter mile at a time is still 30 miles.
O.F. is offline   Reply With Quote
Old 01-21-2017, 03:25 PM   #4
Dega Man
Drives: ZL1
You have nothing to worry about with the oil or filter. I would change the oil/ filter and enjoy your ride.
Dega Man is offline   Reply With Quote
Old 01-21-2017, 03:27 PM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
If the car sat for that long you may need new tires. IMO
Old 01-21-2017, 05:58 PM   #6
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
Tell the dealer to change it. You get 4 (I think) free oil changes. First two years or something like that.
69L48Z27 is offline   Reply With Quote
Old 01-21-2017, 06:48 PM   #7
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631
Synthetic oil will not deteriorate unless you're driving it and then after 3000 to more like 7500 mile, make sure the oil is light amber on the dipstick. If it shows good, I'd change at 1500 miles after break-in.
I'm an industrial chemist - the oil additives ARE NOT going to breakdown at ambient temperatures on a dealer floor. Have fun with the car, follow the break-in instructions. If you're like me you'll be chafing by the time you get to 1250 miles with the break-in max shift limit of 4000rpm...
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631
Toy 2 '09 CGM Z06 3LZ
My DD: '17 Ford Mustang GT
Her DD: '14 F150 Ecoboost 3.5
The_Raging_Bull is offline   Reply With Quote
Old 01-21-2017, 07:22 PM   #8
Crushinator
Crushinator's Avatar
Drives: '15 Z/28 #783
As mentioned, request a service. It's no big deal for them to change the oil. Check the tires for cracks around the outside of the tread. These tires WILL crack if the car was moved when it was too cold outside.
2015 Z/28
A/C and audio
Crushinator is offline   Reply With Quote
Old 01-21-2017, 11:20 PM   #9
--camaro--
Thanks for the replies. Everything looked good and he'll get it changed asap!
Old 01-22-2017, 09:44 AM   #10
FLOW TIE
FLOW TIE's Avatar
Drives: 2015 Z/28 #898
Agree w everything above.
Mine was sitting 2 years as well and I had the same question.
I just mentioned to my salesperson that I wanted the oil/filter changed before I drove her home... didn't even balk, he said absolutely, at no charge.
Doesn't hurt to ask.
FLOW TIE is offline   Reply With Quote
Old 01-23-2017, 01:06 AM   #11
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
The only way you'll know for sure that it got changed is you do it yourself!
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 01-23-2017, 07:03 AM   #12
oakaro68
oakaro68's Avatar
Drives: 2015 Camaro Z/28
Thanks for all your inputs. Oil was still amber/little dark so drove it home with mixed driving hoping to set the rings. Ended up changing it at 333 miles, took delivery with only 28 miles on the clock! Sending an oil sample to Blackstone labs to know for sure.
oakaro68 is offline   Reply With Quote
Old 01-23-2017, 08:52 AM   #13
All2Easy
Drives: 2015 Z/28 #997 Gone 2019 SS 1LE
I'm in the oil business...part of my career was lube oil for transportation (cars, industrial, marine, etc). You would have been fine to leave it in, but I would have done the same as the OP since I am anal about such things.
All2Easy is offline   Reply With Quote
Old 01-23-2017, 09:29 AM   #14
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
If you value your car then do your own service as much as you can....
Any time you let a dealer touch your Z/28 your asking for trouble IMHO.
Mods:
