![]() Drives: 2012 Camaro ZL1 Join Date: May 2016
Moving off in 1st gear on my manual 2012 ZL1
Hi all,
I bought a 2012 ZL1 with, wait for it, barely over 2,000 miles on it (yes, two thousand). It's a new car basically. The engine is free of any dirt of dust, like it just came off the assembly line. The car is flawless: ![]() Anyway, this car is awesome. The V6 was great; the V8 amazing, and this supercharged V8 is truly spectacular. Everything about it. Power, torque, roadholding: the equipment... The (manual) gearbox and clutch took me a day or two to get used to - but just a day, not a month lol. Except for one thing: moving off in first gear: it vibrates hard when I move off from first. The only things I can do to stop this is either not touch the throttle at all and let the clutch come up VERY slowly (I am talking 5 seconds to get it moving), or to give it a LOT of throttle and let the clutch come up VERY fast. A normal moving off is hard. Now to give this some context, I have been driving manual cars since I got my license at age 17, and I am now, ehm... past my mid fifties. So I am not new to standard gearboxes. And I am perfectly OK with this one - except that first gear. But I am not perfect, no-one is. Perhaps my technique is wrong for this transmission/clutch. You al/l know this car well, so.. any ideas, everyone? Mike Brantford, Ontario
Photographer/Engineer/Radio Amateur
http://www.michaelwillems.ca |
Banned
Drives: Camaro Join Date: Mar 2013
I swapped out for a ZR1 clutch then to a Centerforce DYAD. Smooth as silk and I have near as makes no difference 700 rwhp.
#3 | |
PS since it is a ZR1, it has a ZR1 clutch :-)
#4 | |
Banned
And I do believe the ZL1 and ZR1 clutches are different. |
So, no-one any ideas? All your (manual transmission) cars move off smoothly in 1st?
#6 |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
ZR1 clutch has been reviewed and claimed to be worse
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
#7 |
![]() ![]() Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
I have not driven a ZL1, but high horse power clutches shutter. Think of driving a 1 ton truck. My C5 has a 1000hp clutch and it drives just like a 1 ton. It shutters, if I am not fast. I just let the clutch out very quickly and then get on the throttle. Car also has very few miles. Might get better as it is used more.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS 2SS M6 Join Date: Aug 2016
DO three or four comp mode launches...first gear, floor it, should stabilize at 4k...drop the clutch and hang on...if your feelin frisky do a 2 and 3 no-lift...blow all the cob webs out...and if it is a problem waitin to happen...well better now than 1k from home....good luck....btw 55....welcome to the club!
#9 |
Bring It
Sounds like your car might be depressed from all the sitting. Get it out and stretch its legs, and you should have fun yourself doing it. You don't have to drive like a maniac to not drive it like a Caddy either.
Nice car!
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
#10 |
![]() Drives: 2011 Camaro 2SS Join Date: Sep 2015
Sounds like normal clutch shutter, give it a smidge more gas rolling out from a stop
#11 | |
Thanks!
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Miss Con Ception Join Date: Aug 2016
It never shudders. Sometimes in 1st if I quickly close the throttle without stabbing the clutch I get the dreaded driveline rattle.
2011 1SS/RS LS3 CGM
#13 |
Yes, I can do that, but then it takes forever to leave. In practice, you don't have forever so you need a little added power. And that's when it shudders.
#14 |
![]() ![]() ![]() ![]() Drives: 2014 Camaro 2SS 1LE NPP Join Date: Nov 2013
Sounds to me like previous owner hot-spotted the stock clutch. Can create unwanted chatter.
My thoughts on some things:
| Tags |
| 1st gear, clutch, gearbox, zl1 |
