01-23-2017, 06:34 PM | #1 |
Drives: 2012 1LT Join Date: Nov 2015
P0303 Code Help w/Cylinder ID
I've done a bit of searching here and online, but haven't found what I'm looking for.
My daughter's 2012 1LT, LFX equipped V6 is flashing a CEL periodically. The code my scan tool is showing is P0303 Cylinder 3 misfire detected. LOL, which cylinder is #3? I can't find info on cylinder location for this engine. I plan to pull the integral coil for cylinder 3 and place it in a different location to see if the issue is simply a shot coil.
01-23-2017, 08:08 PM | #2 |
Drives: 2012 Camaro rs Join Date: Sep 2016
Driver side is 1-3-5, passenger side is 2-4-6. To answer your question, middle cylinder driver side. You can double check by disconnecting the plug to the coil and starting it. See which cylinder codes.
01-24-2017, 04:47 AM | #3 |
As standing in front of the car looking towards the rear, right?
It's different than the LLT V6 engine then? I found in another thread the firing order on a 2010 with odd cylinders on the passenger's side and even ones on the driver's side.
01-24-2017, 12:03 PM | #4 |
Drives: 2004 GTO & 2005 GTO Join Date: Mar 2014
Boom.
01-24-2017, 06:39 PM | #5 |
My bad. You guys are right. 1-3-5 is passenger bank. 2-4-6 is driver side.
