01-24-2017, 06:49 PM | #1 |
Drives: 2013 Camaro 1LE Join Date: Aug 2016
Need help finding a cam!
I have been looking at cams for a couple of weeks now but I can't find what I have been looking for. I want a mild cam nothing big that I can daily drive. But I want something that makes good power and has a good lope at idle! Any help or feedback would be appreciated!
Mods-1 7/8 Headers, and a cai |
01-24-2017, 06:51 PM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2016
Have you looked at BTR cams??
01-24-2017, 07:20 PM | #3 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Gonna need a tune too...talk to one of the online vendors...dynoSteve...Ted...they can prob spec a cam and send the tune with it...
01-24-2017, 07:26 PM | #4 |
Drives: Camaro and Sierra Join Date: Jul 2012
I had a tsp vvt2 and it fits most of your wants
01-24-2017, 08:04 PM | #5 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Livernois 2c
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
01-24-2017, 09:51 PM | #6 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
If you are particular about what you're looking for, going custom grind is the way to go most likely.
http://www.guerragroup.com/camshaft-help Take a look at that, Pat G will custom spec you a cam for ~$25
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
01-24-2017, 10:43 PM | #7 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
Pat G. or Brian Tooley.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
01-24-2017, 11:42 PM | #8 | |
HTCC Member
I asked the same questions for about a year before I decided to go with the Brian Tooley (BTR) Stage 3 N/A cam. I daily drive my Camaro and have very little issues with it bucking under low RPM's. The way I see it with the BTR cams is like this if you care about your neighbors and have a good relationship then go with the stage 2 cam, but if you don't mind making some noise then go with the Stage 3 cam. You can check out my build thread, it has video, and hopefully it helps. Just skip to the very last page of my build thread. http://www.camaro5.com/forums/showth...=275478&page=7
01-25-2017, 08:49 AM | #9 | |
Drives: 2010 Camaro 454 LSX (SOLD) Join Date: Jun 2013
It's so hard to throw out a blanket recommendation without more info. It's just as much about future mods as it is current ones as most do not like to buy the same part several times. Like another member mentioned out L92 Stage 2C camshaft has been a good all around winner for years. It has great drive ability, killer sound, it's stroker and power adder friendly and works good with a stick or auto. For those that are going to compliment the camshaft with a set of our CNC ported heads we recommend going with the newer L92 Stage 2C-HL if your a stick shift customer that is more N/A or road race inspired our L92 stage 2R-MAX is a great camshaft choice. It is on the aggressive side Also on a side note mod dependent we can send a Mycal hand held to you as well and set you up with our custom remote tuning this keeps you from having to chase local tuning that may or may not be up to par and the ability to load the stock file without having to go back to said local shop for re flashing. This is mod dependent and combo dependent of course. |
01-25-2017, 09:00 AM | #10 | |
Drives: Black L99 2SS/RS Join Date: Mar 2014
01-25-2017, 02:26 PM | #11 | |
01-25-2017, 03:15 PM | #12 |
This is the quote I got from a Houston area shop
http://www.camaro5.com/forums/showth...00#post9492000 |
01-26-2017, 01:29 AM | #13 | |
HTCC Member
01-26-2017, 01:33 AM | #14 | |
HTCC Member
