Old 01-25-2017, 10:07 PM   #1
96_2010_CAMARO
96_2010_CAMARO's Avatar
Drives: 2012 SIM Camaro 2SS/RS , 2010 Tahoe
Send a message via MSN to 96_2010_CAMARO
Smile RGB Dash lightning
This is a little mod I did cause I had a really bad time with the light tube dash being uneven and dim and with this mod I can switch colors and dim the lightning and make it brighter .
( vids with it on and switching colors and without the trim and off )
https://youtu.be/SCU8-pkvISQ
https://youtu.be/oV5S_3LOdUM
https://youtu.be/YfagKF1eDbc
I'm not that good at explaining how I did it and I didn't take much pictures before wrapping it up but it goes like this
( this is not a DIY just giving y'all an idea how I did it )
1- remove the dash trim
2 remove the clips from the dash trim ( its bonded with 3m tape )
3- install the leds facing the engine side ( forward ) and wire it ( search for the abl dash mod you will find a diy showing how to wire it
4- tape the trim back side with 3m double sided tape
5- mount it a little above the way it was leaving a little gap under the trim
6- enjoy
2012 2SS/RS silver ice metallic camaro
96_2010_CAMARO is offline   Reply With Quote
abl, camaro, led, mod, rgb
