Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > International Regions > UK
Old 01-26-2017, 08:07 AM   #1
flying-banana
flying-banana's Avatar
Drives: 2012 SS Convertible
Active Fuel Management Disable Device
I'm looking to stop dropping in the 4cylinder mode when I've the cutouts open.
I don't really want to get at tune at this point, so am looking at one of those Active Fuel Management Disable Device that plug into the OBD2.
Has anyone got any experience of them, possibly one for sale?
flying-banana is offline   Reply With Quote
Old 01-26-2017, 08:50 AM   #2
Gordo-D
Gordo-D's Avatar
Drives: 2015 Camaro 2SS
I looked at converting to LS3, however its all new lifters, lifter buckets, etc etc and then you need a tune to get rid of the AFM.
I had not read or heard about these.
Gordo-D is offline   Reply With Quote
Old 01-26-2017, 08:52 AM   #3
Gordo-D
Gordo-D's Avatar
I confess I didn't know about these, I would love to know more as well.
The Range AFM Disabler Device keeps your vehicle in 8 cylinder mode 100%, preventing the Active Fuel Management system from dropping cylinders.This is the only product that will disable Active Fuel Management without reprogramming the factory ECU. Full power delivery all the time without factory warranty concerns.
More Facts and Features About The Product:
  • Installs in seconds! Plugs into diagnostic port with no tools needed.
  • Best for high load scenarios, such as towing, off-road, icy or snowy conditions or high speed commuting.
  • Range plugs into your vehicle's OBD-II port located under your dashboard.
  • An OBD-II port is the same port that mechanics use to run engine diagnostics or to evaluate emissions.
  • ONE MODULE FITS ALL GENERAL MOTORS (GM) ACTIVE FUEL MANAGEMENT (AFM) VEHICLES! Includes cars, trucks, SUVs both V6 and V8!
Some reviews at the bottom, interesting reading; https://www.amazon.com/Range-Technol.../dp/B00BR1R8N8
Old 01-27-2017, 01:45 AM   #4
RickGM
RickGM's Avatar
Drives: 2013 SS V8 L99 Magnusson Heartbeat
I only use Manual mode which keeps the AFM off (after the first couple of changes) so save your money.
UK Camaro Owner. One of a few.
RickGM is offline   Reply With Quote
Old 01-27-2017, 02:59 AM   #5
flying-banana
True I could do that
Old 01-27-2017, 03:07 AM   #6
Gordo-D
Gordo-D's Avatar
Sounds even cheaper, better as well.
Old 01-27-2017, 05:31 AM   #7
UKCamaro2SS
Need more parking space
UKCamaro2SS's Avatar
Drives: Camaro2SS '17,Audi A6
I used one for a while on my 5th gen , worked perfectly, then I got it turned off by a tune.
Sent from my SM-G935F using Tapatalk
_________________________________________
2017 Camaro 2SS (Euro) , Red Tintcoat, Red/Black interior , NPP, MCC
UKCamaro2SS is offline   Reply With Quote
Old 01-27-2017, 08:45 AM   #8
JamesMyBoy
Drives: 2014 2SS/RS
I've been using mine for almost 3 yrs... Works perfectly, but it will drain your battery if you leave it in with the car garaged for more than three days. It will cost you about one to one and a half mile per gallon on a highway trip, but will add tons of fun and satisfaction at all times.
JamesMyBoy is offline   Reply With Quote
Old 04-04-2017, 08:07 AM   #9
Royal Tiger
Drives: 2013 2SS/RS Convertible
I have the Rabge Device and it works flawlessly. I remembered to take it out a day or two before I took it to get inspected & emissions tested and they failed it as the computer diagnostic said "not ready to test". I'm guessing I need to drive it some without putting it back in and take it back. Does the always drive in M mode really keep the beyond stupid AFM off?
Royal Tiger is offline   Reply With Quote
Old 04-05-2017, 10:41 AM   #10
RickGM
RickGM's Avatar
Yes. See post #4
Old 04-05-2017, 11:40 AM   #11
JamesMyBoy
Drives: 2014 2SS/RS
I believe you have to be in M (or S) AND use the paddles to shift in order to disable AFM.
Just putting it in M will not turn off AFM by itself... at least it didn't for me.
Old 04-05-2017, 02:27 PM   #12
RickGM
RickGM's Avatar
Of course. Why would you be in M if you weren't going to use the paddle shifters?
Old 04-05-2017, 02:50 PM   #13
JamesMyBoy
Drives: 2014 2SS/RS
FWIW, According to my owners manual:
With the shift lever in M (Manual Mode) position, and without using the Tap Shift controls on the steering wheel, vehicles with any axle other than GW8 will be in Sport Mode. Sport Mode provides firmer, quicker shifting. The transmission will shift automatically until the Tap Shift controls are used.
Old 04-05-2017, 03:10 PM   #14
RickGM
RickGM's Avatar
Post #4
