Old 10-20-2009, 09:05 AM   #1
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Jack stands
Where is the best place under the car to put the 4 jack stands for winter storage?
ROD1 is offline   Reply With Quote
Old 10-20-2009, 10:14 AM   #2
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
If you are storing your car for the winter you really don`t need to put your car on jack stands, it won`t hurt the suspension to sit for a few months. I`m not trying to make anyone look uninformed but why do people think if you store a car it needs to be off the suspension? Collectors have cars that sit for years.
mickss is offline   Reply With Quote
Old 10-20-2009, 10:23 AM   #3
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
I wouldn't bother with the jack stands. It's an urban myth the the tires will get flat spots (used to happen with the old bias ply tires, but not with radials.) You won't harm the suspension either. Put stabilizer in the gas and a battery tender, you'll be good to go in the spring.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 10-20-2009, 10:37 AM   #4
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
its hard to get a straight answer around here with so many know it alls i would put it up too cause of the tires and you might want to mod something under the car while its stored maybe someone will show us, look for exhaust mod pics on the forum some show jackstand locations .
klatterblast is offline   Reply With Quote
Old 10-20-2009, 10:40 AM   #5
Timberline
Timberline's Avatar
Drives: 2010 SS/RS,LS3,M6,VR
I agree if the car is setting for a few months, jack stands are not neccessarily needed but you will encounter flat spots on the tires that will be noticeable for the first mile or two of driving and as you continue driving the tire will smooth out. Yes, I know radial tires are not supposed to do that but they do. I know this is fact as my hot rod and my 3500 Crew Cab dually shakes for the first mile or two after setting for a couple of months.
In short jack stands will help the tires, no worries about the suspension.
As for loctions for the stands I am not sure since I just picked up my car last Saturday...havent had a chance to look......the car seems to stay in a constant state of motion.
2SS/RS, Victory Red, Black Leather, LS3, 6spd, Polished wheels - R6P -
Timberline is offline   Reply With Quote
Old 10-20-2009, 10:43 AM   #6
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
If you look in the owners manual it should show the proper jack points for changing tires.... Use the same spots for stands.... And the extra precautions won't hurt ....
Old 10-20-2009, 10:54 AM   #7
trm0002
VIN #2G1FT1EW6A9100074
trm0002's Avatar
Drives: 2010 CAMARO 2SS/RS RJT VIN 00074
Send a message via AIM to trm0002
Agreed. It costs NOTHING to put the car up on jack stands on the chance of flat-spotting the tires and it tends to stop the urge to drive in the middle of the winter on roads that "aren't that bad..." dead in its tracks.
trm0002 is offline   Reply With Quote
Old 10-20-2009, 12:28 PM   #8
ctk1
Camarofanatic
Drives: 1969 SS, 1998 RS, 2010 VR 2SS/RS
Put 1 under each control arm in the front, basically at the bottom of the strut. Put the other 2 under the trailing arms for the rear suspension. Basically you want to keep the tires off of the ground to keep them from flat spotting, but at the same time you don't want to unload the suspension and let it sit like that all winter which is very hard on it. Trust me, definitely do this to avoid flat spots. I have 2 other cars I park for winter, and after I did not use jack stands and my very soft Kuhmo tires flat spotted, I will do it to every car I park from now on. Mild flat spots will go away, but I had a set of tires that I had to replace because of letting it sit all winter.
ctk1 is offline   Reply With Quote
Old 10-22-2009, 08:55 AM   #9
ROD1
Retired
Uhmmmm................... No!
Old 10-22-2009, 08:59 AM   #10
ROD1
Retired
I also read its good to unload the suspension. I would think it would be bad on shocks and struts to let the wheels hang.
Old 10-22-2009, 09:37 AM   #11
dmo
dmo's Avatar
Drives: 2SS RS
Send a message via AIM to dmo
Here is an image I found in the camaro5 forums. Can't get any easier.
dmo is offline   Reply With Quote
Old 10-22-2009, 09:59 AM   #12
trm0002
trm0002's Avatar
If the key reason to jack up the car is tire "flatting" and you don't want the suspension completely unloaded, then don't completely unload it. Jack it up enough to take most of the weight off the tires but not enough to lift them off the ground. Pretty simple IMO.
Old 10-24-2009, 09:05 AM   #13
ROD1
Retired
I'll buy that...will do!
Old 10-24-2009, 09:14 AM   #14
80Zedder
Cheif Pounderhard
80Zedder's Avatar
Drives: 80camaro/Avalanche/srt8charger
Sorry guys, but the proper thing to do for winter storage is to put the vehicle on jackstands. Not for fear of flatspotting the tires, and not to unload suspension, but to releive the weight off your wheel bearings to prevent flat spotting them. It does happen and it has happened on my camaro after 5 months of sitting in one spot.
So unless you plan on driving it once every few weeks, i would put your car on stands.
80Zedder is offline   Reply With Quote
Auxiliary input jack slick rick Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 55 11-01-2011 01:25 AM
Just thought I'd share TAG UR IT Off-topic Discussions 33 05-12-2011 04:04 PM
where do you jack up the car if you have a flat or oil change /also wheel lock photos camarossrs2150 5th Gen Camaro SS LS LT General Discussions 30 11-10-2009 12:45 PM
If the El Camaro makes it to production.... Silverado General Automotive + Other Cars Discussion 8 02-21-2008 11:17 AM
