Old 01-27-2017, 06:36 PM   #1
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Unhappy Is a aftermarket torque converter worth it??
I have a L99 TVS 2330 with 12lbs of boost, probably making somewhere around 550rwhp and a factory stall. Since i have gone to the track the last 3 years, i was able to 11.8 once only. i also have 18x10 weld rts rims with 555r drag radial for when i do go. My 60ft times have been 2.0s and up and i think i have gone 1.9 once as well. From what iv been reading and what people have been suggesting to other members is that i need to get a aftermarket torque converter. I just spoke with my tuner he said that he hated torque converters with my setup because it makes it impossible to hook and totally impossible to launch and stick the vehicle. With everything that i have put in the my car i should be running high 10s if anything.
Question is? Did i make the right choice in ordering a Circle D multi-disk 3000-3200 rpm stall?
He really got me thinking that i didnt make the right choice. Maybe i did i dont know. I didnt know what else to do to help get me down the track quicker with all the money i spent in upgrades. Thanks for yall input
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
lincoln361 is offline   Reply With Quote
Old 01-27-2017, 07:35 PM   #2
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
If you can't hook, you need better tires! A stall will allow you to launch harder, but without better tires.......blah.....
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 01-27-2017, 08:13 PM   #3
lincoln361
lincoln361's Avatar
So should i stick with the factory stall and get some slicks instead,or should i stick with the stall and get 17in welds with slicks
Old 01-27-2017, 08:22 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Pat G tunes your car?
Can you post your best time slip? Let's start there.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 01-27-2017, 08:44 PM   #5
lincoln361
lincoln361's Avatar
Yes it is tuned by pat g.
Old 01-27-2017, 08:48 PM   #6
lincoln361
lincoln361's Avatar
This is best time slip. The post before was my most recent with new 555r drag radials 305/45/18
Old 01-27-2017, 11:16 PM   #7
G701LE
G701LE's Avatar
I would say both are needed. Better tires and a stall. You obviously aren't hooking already if you can't break 2's in the 60ft.
Old 01-28-2017, 09:20 AM   #8
lincoln361
lincoln361's Avatar
Mickey some mickey thompsons tires are needed. But would a stall still be beneficial if i have a stickier tire or am I still going to spin. I told circle d mostly street. Im just know with the power i make I should be low 11s high 10s on a good night. Just wasnt sure if it was the stall that i needed that or tires. I havnt tried the mickeys yet
Old 01-28-2017, 02:04 PM   #9
ZL1C7
ZL1C7's Avatar
Drives: 2023 SS 1LE 10SPD
x2 on the Mickeys.. You will be ok with the converter change after you get the good tires on.. What concerns me is the huge gap in between your bad runs and good runs. You need consistency to make progress. What are you doing with the traction control? on or off?
ZL1C7 is offline   Reply With Quote
Old 01-28-2017, 07:18 PM   #10
G701LE
G701LE's Avatar
The converter will help launches so long as you can hook = TIRES
Old 01-28-2017, 09:29 PM   #11
Pro Stock John
Writer
I've tried 4-5 tires. 555Rs are a good street/entry level/lower power tire. I went 12.3@112 on them stock engine.
Then NT05Rs, 1.59... but still some spin. Tried MH's, about the same for me.
Then Hoosier slicks, 1.47. I have had MT Pros on my car and I can tell they are very good, and friends have gone 1.43 on them.
PROJECT HEAVY CHEVY
Old 01-28-2017, 09:31 PM   #12
Pro Stock John
Writer
So yeah you have outgrown the 555Rs, keep them for the street and run a better tire at the track.
PROJECT HEAVY CHEVY
Old 01-29-2017, 07:49 PM   #13
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
A set of 305/45/18 M/T with 18psi and a 3000 or 3200 stall. You need some stall with just 550rwhp.
You don't have enough H/P to make it impossible to hook. With the rite tire.
This was over 5 years ago with 585rwhp. I ran a FTI 3200 with the 6L. Back then still had the stock 20" wheels with 555R. My 60' was low 1.60 and high 1.50. I had no problem getting it to hook. That with the Whipple
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 01-31-2017, 10:03 AM   #14
lincoln361
lincoln361's Avatar
[QUOTE=ZL1C7;9529558]x2 on the Mickeys.. You will be ok with the converter change after you get the good tires on.. What concerns me is the huge gap in between your bad runs and good runs. You need consistency to make progress. What are you doing with the traction control? on or off?[/QUO
Yeah the track is 2 hours away and i work shift work as well. So i dont get to go as much as i would want to. I have the traction control off.
