Old 01-29-2017, 04:00 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
simple nitrous system for fun
Im thinking about adding nitrous . LS3 mods in sig. I want something simple that wont damage my motor if thats possible. I know next to nothing about nitrous. Im not racing i just want some more power on the cheap and relatively safe. maybe 50hp. looking at this system or something like it. http://www.nitrousexpress.com/190432...lb-bottle.html how much would i loose hp wise after tune when im not using it.
JCunningham is offline   Reply With Quote
Old 01-29-2017, 10:53 AM   #2
Dwright
Drives: 2011 Camaro 2ss
I have a stage 2 zex kit brand new. I am not going to use if interested. Pm me. From my understanding if tuned correctly you shouldn't loose any on a small shot. When up over a 75 shot or more timing needs to be adjusted either through running dual tunes or a lingerfelter box that will retard the timing when nitrous is activated
Dwright is offline   Reply With Quote
Old 01-29-2017, 11:11 PM   #3
BradySS
Drives: 2010 Camaro 2SS
I would get the lingingfelter lnc2000. That way when you arm the nitrous it will pull the timing. Not armed you're the same as before. Has a two step too. Its about $275.00
BradySS is offline   Reply With Quote
Old 01-29-2017, 11:33 PM   #4
FieroItaliano85
Drives: 2014 2SS/RS L99
Spray a dry shot before the maf...up to 150 you're good. I did that with mine. Car loves nitrous
2014 2SS/RS AGP Twin Turbo
FieroItaliano85 is offline   Reply With Quote
Old 01-30-2017, 07:28 AM   #5
polizzio
polizzio's Avatar
Drives: 2012 1LT SIM Camaro
Try more like $670 new, and on ebay. $875 at Summit Racing.
polizzio is offline   Reply With Quote
Old 01-30-2017, 07:51 AM   #6
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
Pretty sure it's $274.95
http://www.lingenfelter.com/product/...l#.WI82sH9X3F4
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 01-30-2017, 08:04 AM   #7
polizzio
polizzio's Avatar
Originally Posted by Buschman View Post
You are right, my bad, I searched the wrong controller.
Old 02-03-2017, 06:56 AM   #8
Mdp
Mdp's Avatar
Drives: Camaro
Few guys using nitro system. Can anyone else give feedback?
Mdp is offline   Reply With Quote
