Ghost Cam??
Hey, can anybody enlighten me on how to achieve this effect? Is it just a matter of playing with the timing in the idle cells?
I have HPT Pro version, so just looking for a little insight before i go experimenting on my own. Thanks, Scott |
![]() Drives: 2010 Camaro Join Date: Oct 2014
Don't waste your time, buy a cam if you want the sound. But idle over speed and under speed timing correction is where you would change it, you'd make it really agressive.
2010 2SS LS3 228/235 Cam Motion custom ground cam, AI 280cc ported heads, Dynatech 1 7/8" long tubes, catless mids, CAI intake, ATI 10% UDP, CORSA cat back, Slp 160 tstat, gm 3.91s/Tru trac, EFI LIVE tuned by myself
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Engine > Advance > Idle Adaptive Spark Control >> both the Overspeed and Underspeed for P/N and Gear. Multiply each whole table by 1.2, 1.4, or 2 - until you get the desired idle effect. It may or may not work how you're expecting. Don't mess with the Idle Spark Advance table.
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
I wouldn't bother, it's just for the sound and you force the engine to essentially misfire and idle poorly.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
Not a true statement. And, to each their own. Yes, the spark will swing moreso within a larger range, and the idle quality will roughen up. Adaptive Idle correction, by multiplying by a larger value, will swing the idle back and forth in a larger range. It's always nice to have a large cam lope, but you'd be faking it with the spark swings. No misfires happening.
| Tags |
| cam, cam sound, fake, ghost cam |
