Old 02-01-2017, 10:46 PM   #1
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Changing pulleys on striker vs stock
With the stock ls3 and whipple, when you changed pulleys, next size down was about 2psi, according to whipple website. Does that still hold true for stroked applications? I'd like to pulley down about since I'm only at 6psi now that's I'm stroked. Was 11 before. I'd like to try around 15 psi, but don't know how to know which pulley I need without buying a bunch and trying. Thanks!!
Caswell239 is offline   Reply With Quote
Old 02-02-2017, 04:00 PM   #2
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
If I recall correctly, Whipple states that for every 1/8" drop (.125") in pulley diameter, it will increase boost approximately 2 psi. I believe those numbers are irrespective of engine size. So, if you are still running the 4" stock Whipple pulley for the LS3, and are at 6 psi, then dropping to a 3.5" would put you around the 15-16 psi mark.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 02-02-2017, 04:04 PM   #3
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
I called whipple and they said each 1/8 is 1 psi. I'm currently at 6psi on 3.75 pulley so if I go with a 3" I'll at 12 lbs, which is probably more then a 6 rib can handle.
Old 02-03-2017, 11:22 AM   #4
hillshooter
Drives: 2015 Camaro SS commemorative
so you lost 5PSI just going from 376CI to 416CI? Same pulleys?
hillshooter is offline   Reply With Quote
Old 02-03-2017, 01:07 PM   #5
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Yes, exact same pulleys.
Old 02-03-2017, 03:29 PM   #6
cc-rider
Drives: 2010 Camaro SS
Your probably lower compression now too. Which would likely contribute to the drop in body too along with the bigger cubes.
cc-rider is offline   Reply With Quote
Old 02-03-2017, 03:30 PM   #7
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Was 10.7 before, now about 10.5 cr
