Old 02-04-2017, 09:51 AM   #1
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
I'm going to do it ... need advice
I've decided that come spring, my dad, may nephew and I will be pulling my intake and manually cleaning the manifold, runners and valves (and hopefully installing an Elite E2 can) possibly changing the plugs since I'm going to pull them anyway to make turning the engine over easier.
It's already been suggested that I replace the upper and lower intake gaskets since I'll have +/- 50,000 miles on the car.
What I'm asking for is any other tips or suggestions that might make this go smoother or give me better results.
Thanks
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 02-04-2017, 10:21 AM   #2
polizzio
polizzio's Avatar
Drives: 2012 1LT SIM Camaro
My questions would be why go thru all this effort?
What negative engine performance symptoms are you currently experiencing?
If you are so very concerned about PCV oil carryover into the intake, why don't you have a catch can on there now or ASAP? (I do have an elite on mine)
polizzio is offline   Reply With Quote
Old 02-04-2017, 06:45 PM   #3
DonM
Camaro #4
DonM's Avatar
Because I have seen the pictures of engines that have gone without a catch can for fewer miles than mine (I have just under 50K now). As of yet, I haven't been able to afford a (quality) catch can, but I plan on getting one before, or shortly after the cleaning to prevent any build up from happening again.
Don M
Old 02-04-2017, 07:44 PM   #4
ELEMENTSEND
ELEMENTSEND's Avatar
Drives: 2013 Victory Red Camaro RS Convert
If you can't afford a quality catch can yet. Just buy some of this and follow the directions on the can. It really works.
My .02
JP
ELEMENTSEND is offline   Reply With Quote
Old 02-04-2017, 09:18 PM   #5
Chuckem12
Drives: 2015 Camaro SS (2SS/RS)
Why not try the Moroso Catch Can? About $150 and they've had proven records on multiple platforms for many years. IMHO, I think its nicer looking than most if not all the other catch cans.
Chuckem12 is offline   Reply With Quote
Old 02-05-2017, 07:44 AM   #6
DonM
Camaro #4
DonM's Avatar
My .02
JP
I'm afraid of chunks breaking loose and getting into the cylinders and causing damage, but that IS what I intend to use for the manual cleaning, besides if I'm going to clean it, I'm going to do it right.
The Elite seems to be the favored can around here and it's only a few dollars more. My problem is that I have a family of 4 (3 disabled) and I'm the only source of income.
Don M
