Old 02-09-2017, 09:09 PM   #1
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
Any weak links to worry about in the motor on this kind of shot on a progressive controller? Mods in signature. Primarily for 1/2 mile, and lower shot for drag racing.
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 02-09-2017, 09:32 PM   #2
Strong66
Drives: 2013 SS whipple
You will need to upgrade fuel system or run a standalone
Strong66 is offline   Reply With Quote
Old 02-09-2017, 10:06 PM   #3
booneSS13
booneSS13's Avatar
I have a stand alone, a direct port manifold, and wideband. forgot to mention that
Sent from my VS990 using Tapatalk
Romans 5:8
Old 02-10-2017, 08:52 AM   #4
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Ring gap? Make sure to run a proper range cold plug and tune obviously will make or break a bigger shot like that
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 02-13-2017, 12:29 PM   #5
booneSS13
booneSS13's Avatar
I'm running 0.26 top ring and 0.28 2nd on a 4.070 bore. Just wanted a few extra opinions before I pull the trigger later. What plugs should I start with?
Romans 5:8
nitrous, spray
