10-21-2009, 02:56 PM | #1 |
Drives: 2010 camaro ss/rs m6 Join Date: Oct 2009
WHICH HEADERS + EXHAUST Dealers welcome
Hey guys im looking for some headers and complete exhaust. I want a true bolt up system with no welding. My car is going to be SC probably Magnuson but im waiting on Whipples #'s. What should i order for exhaust. Im thinking 17/8" Kooks or ARH and MagnaFLows 3" competion cat back system, but im not sure if they will bolt right together. I WANT LOUD AND OBNOXIOUS WITH A DEEP TONE. IT ALSO NEEDS TO BE CATTED I DONT WANT ANY CODES THROWN. part numbers and or websites would be greatly appreciated. Thanks
10-21-2009, 03:05 PM | #2 |
Drives: Black s2000, 749 ducati dark Join Date: Jul 2009
If you are going with a cat back system ARH has a shorty system that will bolt up to whatever cat back you want. However my recommendation is to buy the whole ARH set up and then just pick up and axle back. If you want to talk further give us a call at the shop and we'll get you taken care of. 631.608.1986
Anthony |
10-21-2009, 03:08 PM | #3 |
Okie doke
I vote and ARH system and Magnaflow 3" Catback .. Sounds GREAT.
Crowley
10-21-2009, 03:22 PM | #4 |
let me get this correct if i buy headers with the X pipe, all i will need as an axle back of my coice?
10-21-2009, 03:23 PM | #5 |
Yes.
10-21-2009, 03:40 PM | #6 |
would you recomend the 17/8 headers or the 2" for a supercharged application. also if you recomend the 2" is it a alot harder to install then the 17/8?
10-21-2009, 03:59 PM | #7 |
Drives: Wild Cherry Join Date: Nov 2008
+1
2010 RJT 2SS/RS L99 CAMARO ARH 1 7/8" LT HEADERS W/ HF CATS MAGNAFLOW 3" COMP EXHAUST ADM PERFORMANCE CAI ADM PERFORMANCE CUSTOM TUNE ADM PERFORMANCE PORTED THROTTLE BODY ADM PERFORMANCE TRANS COOLER 3.45 GEARS BMR TRAILING ARMS |
10-21-2009, 06:09 PM | #8 |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
You are going to throw codes with any LTH system. catted or not
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
10-21-2009, 06:17 PM | #9 |
10-21-2009, 07:11 PM | #10 |
Drives: 2010 Camaro SS Join Date: Sep 2009
i thought the whole point of the catted system was so you dont throw codes. please explain why you would still throw codes with headers. Im not saying your wrong im saying i dont know enough about the computer stuff. and if you do throw codes whats the point of he cats then?
10-21-2009, 07:41 PM | #11 |
Drives: 2SS w/ ZZ427 Package!! Join Date: Oct 2008
I would suggest the ARH system with cats...and then an axle-back system. If you want it really to sound loud, I have an entire exhaust in the bed of my truck that I took off because it was too loud for me.
It sounds like a big block!! But I would definitely go with the ARH, and a 3 inch axle back system...then custom fit them together. That is what I did...and you will love it! |
10-21-2009, 08:05 PM | #12 |
thanks for all the input. Id also like to know what the benifit is of the Cats if they do still throw codes. ZZ what exhaust is in the back of your truck i might be interested.
10-21-2009, 09:18 PM | #13 |
2010 Camaro 2SS/RS - Roto-Fab CAI, ARH 1-3/4" LTs w/cats, LMR tune, KW V3 coilovers, Pfadt F&R sway bars, end links, rear trailing arms, tie rods, solid subframe bushings, HPS brake pads |
10-21-2009, 09:31 PM | #14 | |
The advantage of having cats is passing inspection. They also keep a little back pressure which helps TQ. |
Similar Threads | ||||
LG MOTORSPORTS LONGTUBE HEADERS AND EXHAUST | RLHMARINES | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 09-24-2009 04:57 PM |
Stainless Works Headers & Exhaust Systems | EVS Motors Inc. | V8 Bolt-Ons & Tunes | 6 | 09-23-2009 09:35 PM |
Suggested mounting point for AEM UEGO sensor on ARH headers and exhaust | SoloSK71 | Tuning / Diagnostics -- engine and transmission | 11 | 08-21-2009 06:42 PM |
We just picked up Stainless Works Headers & Exhaust Systems | EVS Motors Inc. | V8 Bolt-Ons & Tunes | 12 | 08-08-2009 02:18 AM |
Headers & Exhaust | Got1-4mywife | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 06-04-2009 01:56 PM |
