![]() ![]() Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Stock 6.0 head gasket selection
So im building a 402 6.0 iron block, the rule for picking gaskets diameter is .030-.060 over the stock bore right since the top of cylinder is chamfered at the top or does it needs to be all the way up to .100 on gasket selection. I will be using a agp twin kit.
![]() Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
Use LS9 gaskets.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
What diameter size tho
They are 4.1
Ok thxs
