Old 02-18-2017, 07:50 PM   #1
Chaotic73
BUMBLLB
Chaotic73's Avatar
Drives: 2010 Camaro 1LT/RS
Replaced DRL's
Finally got around to replacing my DRL's yesterday. Replaced them with the Morimoto XB LED's and found an adapter on ebay so it would be plug and play. I also had to buy a set of factory Fog light housings and use the 2 small adapters for the top mounting holes and the lower adjustable mounting post. I like them much better than what I had in the DRL's and they have a cut off line so no more blinding people.
Below are links to the lights and the adapter.
https://www.theretrofitsource.com/ch...to-xb-led.html
http://www.ebay.com/itm/331643054969...%3AMEBIDX%3AIT
These are the factory fogs I bought to get the plastic adapters and the adjustable mount.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Chaotic73 is offline   Reply With Quote
Old 02-18-2017, 08:11 PM   #2
davesnever
davesnever's Avatar
Drives: mine
Yeah those look much better and brighter than the stock units, never been a fan of any of Chevy's fog lights.
davesnever is offline   Reply With Quote
Old 02-19-2017, 02:01 PM   #3
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Subscribed
GVA 45TH 2SS is offline   Reply With Quote
Old 02-19-2017, 04:55 PM   #4
Chaotic73
BUMBLLB
Chaotic73's Avatar
Old 02-20-2017, 09:51 AM   #5
davesnever
davesnever's Avatar
Drives: mine
Nice that you were able to find a light that was actually designed to replace the factory fog and kudos to you for taking it a step further, nice clean install too with the wiring adapters. I would like to do the same but the problem is I have halo led's installed in mine right now and I those look too nice to cut open and butcher to retain the same effect.
Old 02-20-2017, 01:27 PM   #6
Chaotic73
BUMBLLB
Chaotic73's Avatar
Looking at them I'm not sure there is room inside the housing to put halos.
Old 02-24-2017, 01:07 PM   #7
BigMacLA
BigMacLA's Avatar
Drives: 2012 2ss
How hard is it to install?
BigMacLA is offline   Reply With Quote
Old 02-24-2017, 04:35 PM   #8
Chaotic73
BUMBLLB
Chaotic73's Avatar
If you get all of the parts I listed it's pretty straight forward. took my about 30-45 min to do the swap.
