![]() Drives: 2014 Spring Edition SS Join Date: May 2014
New StopTech Trophy series brakes, Z-28 hubs, NACA duct system
I hope I finally have my braking system where it needs to be! Also replaced the old OEM hubs with Z-28 hubs and added camber plates and a track ready alignment. Work done by Justice Pete and the fine folks at JPSS!
Looking good
![]() Drives: 2010 1SS RS M6 Join Date: Jan 2015
To pretty to use!
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
CAR-DASHIAN
Drives: 2015 Ashen Gray Metallic 2SS/RS L99 Join Date: Nov 2015
Moving art!
PERFORMANCE: ColdAirInductions CAI, ADM Race Scoop, Cordes Performance Racing Ported TB/IM/Custom VVT Cam, WFO Milled Heads, Stainless Power 1 7/8" LT/3" HFCs, JBA 3" Comp. Cat-Back, Taylor 10.4mm Plug Wires, Tim King Performance Stage 3 6L80, Circle D Billet 3600 Stall, Nic D ECM/TCM Tune, - 458rwhp/413rwtq (prior to PIM), Forgestar F14 (F)18" / (R)17" Rims.
SUSPENSION: Z/28 Rear UCA Bushings, Carlyle Racing LCA/TA, BMR Adj. Toe Rods/Xtreme Anti-Roll Bar, Justice Pete Castor Locks/Radius Rod Inserts, Pegasus Billet Rear Cradle Bushings, Mickey Thompson Street SS II 305/45/17 tires. |
Instagram: Sangstah
that NACA duct setup is legit, very nice!
#6 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 M6 Camaro SS (RIP) Join Date: Nov 2014
Wanna trade?
Speed engineering 1 7/8 LTs, CAI inc Cold Air Intake, offroad connectors, Solo performance axle back with J pipes, tune, and in need of a driver mod LOL
#7 |
I wonder if a dual outlet duct would work if mounted in the center.
Orange Krush II
#8 |
CAR-DASHIAN
I think the benefit it gives would be diminished by the extra turns and distance required to travel all the way from the center as opposed to a pretty straight shot from the sides. Even under hood temps might have a small effect on its efficiency.
I am not knowledgeable on this topic - just think out loud so to say.
#9 | |
#10 |
CAR-DASHIAN
I concur - there is no doubting Justice Pete.
The pic looked like they were out to the edges - not in the center, unless I missed something. Enjoy!!
#11 |
How expensive were the hubs and do you know what the P/Ns for the ducts are??
Orange Krush II
#12 |
![]() ![]() ![]() ![]() Drives: 2012 1SS M6 IOM Join Date: Dec 2012
This setup looks like a corner killer.
My question is, what's the difference between the Z/28 hubs and your stock ones? I understand the rear is beefier, but I don't understand the front swap.
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018. |
#13 |
![]() Drives: 2010 Camaro 2SS Join Date: Feb 2017
That looks amazing, I would love to see how that responds on the sharp canyon turns we got over here. I need to switch my Brembo's.. not sure how expensive your set up is$$$.
"To be prepared for war is one of the most effective means of preserving peace." -- George Washington ___________________ #CANYONSS |
#14 | |
Drives: Camaro Justice Join Date: Jun 2007
Left 23129155 Right 23129156 http://www.jpssonline.com/shop/z28-rear-knuckles The NACA ducts I picked up in a race shop in Charlotte. I have about a dozen sets on the shelf. They are perfect for the 5th Gen. Too bad they were discontinued and in a 'close out' box. Not sure what comes after these are gone, but I am sure we'll find something. |
