Old 02-19-2017, 05:56 PM   #1
RSCHRIS
RSCHRIS
RSCHRIS's Avatar
Drives: 2010 Camaro SS/RS
What are the widest Tires to fit on a 1in lowered 2010 camaro ss
ok I have a 2010 Camaro SS and lowered it with Eibach 1inch lowering springs and Koni yellow adjustable struts and shocks. My question is what is the widest tires I can run on the front in a 20in or a 19in rim and what offset should I go with to fit said tire and wheel. I do like the ZL1 wheels but am not shore if they would fit since I lowered the car, I had 275/40/20 on my 20x8.5 american racing torque wheel with a 32mm offset but had to go to a stock size tire , because it was rubbing under my strut on the front. the back I have a 295/40/20 the rear rims have a 30mm offset and they fit good .
RSCHRIS is offline   Reply With Quote
Old 02-19-2017, 06:04 PM   #2
mma
Drives: 1LE
I don't know about the widest wheels, but I was able to go ZL1 wheels on 275/40/20 on fronts and 315/35/20 rears on 1" BMR drop. did not rub.
mma is offline   Reply With Quote
Old 02-19-2017, 06:15 PM   #3
RSCHRIS
RSCHRIS
RSCHRIS's Avatar
wow thanks for the info.
Old 02-20-2017, 07:50 PM   #4
stpijb
Drives: 2012 Camaro 2ss L99
The problem I'm seeing on the front is if the yellows are like the orange konI struts the stock are close to rubbing. Will the extra width cause them to rub? I might have 1/4 inch clearance max between strut and tire.
stpijb is offline   Reply With Quote
Old 02-20-2017, 08:29 PM   #5
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
20x10 ET 23
20x11 ET 43
275/40/20
315/35/20
PK Auto Design is offline   Reply With Quote
Old 02-20-2017, 10:09 PM   #6
jrhagen
Banned
Drives: Camaro
I have this, fits great.
jrhagen is offline   Reply With Quote
Old 02-21-2017, 06:31 AM   #7
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Originally Posted by PK Auto Design View Post
20x10 ET 23
20x11 ET 43
275/40/20
315/35/20
- He's right
Check out the 1st post on
http://www.camaro5.com/forums/showth...t=reproduction
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 03-11-2017, 10:37 PM   #8
SYNGSS
SYNGSS's Avatar
Drives: 2011 Camaro 2SS/RS 6 Manual
Rear: 315/35/ZR20
Front 275/40/ZR20
on a 1" Drop
[Dyno Results] 684rwhp 602.84Pktq at 6600rpm. Mods: too much to list.
SYNGSS is offline   Reply With Quote
Old 03-12-2017, 11:09 AM   #9
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
Originally Posted by SYNGSS View Post
Rear: 315/35/ZR20
Front 275/40/ZR20
on a 1" Drop
SYNGSS...Wow! That's one AWESOME looking ride!
Check out my build thread
Old 03-12-2017, 05:09 PM   #10
SYNGSS
SYNGSS's Avatar
Thanks...It took me 4 years to get to were it is now. this years mods are an ECS Supercharger,Alky-Meth injection and MGW Shifter, MSD shiftlite, Pillar Guage pod with a boost and AF Gauges, Nitto 555 G2 rear tires and I'm removing the factory stripes and replacing them with painted on stripes.
Old 03-12-2017, 06:06 PM   #11
pyroguy
pyroguy's Avatar
Drives: ABM #832
Thanks...It took me 4 years to get to were it is now. this years mods are an ECS Supercharger-Meth injection and MGW Shifter, MSD shiftlite, Nitto 555 G2 rear tires and I'm removing the factory stripes and replacing them with painted on stripes.
I've had mine for 4 years in April and while I'm starting to get it where I want it, the problem for me is that things are going to get expensive now. My next plans are a Stage 3 LSA supercharger upgrade (2.5" pulley with a BTR Stage 3 cam and supporting accessories), firming up the rear to prevent wheel hop and cradle movement, adding much bigger meats out back (hence the subscription to this thread), and add a new spoiler, hood and factory ground effects. I may even lower the car again if I find a spring I like that isn't going to buck me around too badly on the crappy PA roads.
Old 03-14-2017, 08:10 AM   #12
copoz28
copoz28's Avatar
Drives: 2010 2SS-RS, IOM, M6
SYNGSS that's one sweet ride...
2SS/RS, Inferno Orange, 6sp, Eibach lowering springs, Eibach adjustable sway bar, Exhaust 2.5" dumps before axle, New ERA OTR intake, TSP LS3 225/230 .617/.612 on a 112LSA cam,
Rocker arm trunion kit, ported/polished heads, JRE Tune, ARH Headers, G-Force Axles, 3.91 Gears, Eaton Detroit Truetrac /w Billet Caps, MGW Shifter,
DynoTech Driveshaft, E2X Catch Can .
copoz28 is offline   Reply With Quote
Old 03-14-2017, 08:56 PM   #13
SYNGSS
SYNGSS's Avatar
Thanks
Old 03-14-2017, 09:01 PM   #14
JusticePete
Drives: Camaro Justice
325/30/19 are no problem.
lowered, wheel and tire package
