Old 02-20-2017, 11:09 AM   #1
frenchsquared
frenchsquared's Avatar
Drives: 15 Z28, 01 Corvette, 96 Corvette
First Track Day! WOW!!!
Took the Z28 to an open lap day at Pueblo Motorsports Park. Not a bad turn out. I think there were 16 cars and over 30 bikes that started. Two GT4's, C5 z06 Track set up, Gen5 ZL1, and an assortment of others.
First... WOW... this car is basically perfect bone stock. I am amazed at how well it did right off the showroom floor. I will be changing the brake fluid and going to the track alignment just because I want to.
When I first got there 2 or 3 guys noticed the car and came to check it out. Most just thought it was a Camaro with some upgrades. The two GT4 cars new what it was.
but after the first session... new game...
Pretty much every other driver came to see that car as well as a lot of bikes. I had two guys tell me they had to come see the car when they saw it actually pull away from the GT4's in the straights. yep... I guess I actually pulled on them.
Next I had a group of 3 guys come over to ask all about the car. They had no idea what a Z28 was and thought a ZL1 was the top dog. One of them was in a lotus. Asked all about my line. How many years I had been driving, what was my best lap, and what all mods did I have on the car. He could not believe the brakes we stock. He tried several times to follow my lines but could not keep up. Was blown away by how fast the car was. Said I had him by 10 seconds.
My 1996 Z51 on R7's ran a 1:56. Nice warm day. This day was only about 60 and I ran 2 1:46's in the Z28. I am sure there is a more in the car. First day in the car, sport mode 3, 2nd time on that track, yes there is more in the car.
I knew 1 of the GT4's which makes this an even better day. He is an instructor for PCA and does a lot, a lot of driving events. Well for a few laps I could see him in my mirror. Never close enough to pass but he was there. I was in traffic and every time I would get behind someone he would clearly gain some ground. Well I decided to slow down and let him by so I could follow him for while. Thought it would be fun. First turn I was on his ass... I had to brake early to not hit him and get on the gas late cause he was in the way. He never pulled at all. Second turn again I was slower then usual. He was a little high and actually lost grip and slide off the track. I was lower and had plenty of power to hold the corner and blew past him on the inside. The Z28 held the corner better and with more speed then his GT4 that day. He was fine, just slide off and was right back on. Wreck two turns ahead of us ended the session.
I can not wait to play with more GT4's. I finally have a car that will corner, brake and accelerate with them. In the past they have always been better at something.
It is very possible the Z28 was the fastest car there that day. The 2nd GT4 was fun to pass but it was a new car. First day on track in that car so not fair to compare. Although it was my first day as well.
The down side of the day is the C5 Zo6 lost it on the first lap of the first session. Slid on a corner and nailed a wall. Destroyed the front end. 3rd session the ZL1 lost it and hit the tires. Nose came off and all air bags deployed. I did not get to play with either of them before this happened.
They are the reason I staid in track mode 3. The track mode was fighting me and does keep the car safer. I know I can pick up speed with a higher track mode.
I did slide around in the seat as others have. I am only 5'10" and 150lbs. I was sliding around and will be looking at options to fix that in a few months. Want to play more. I like the Trofeo tires but I am use to R7's. I cannot wait to get new R7's on this car.
The gas tank is way to small. I took 10 gallons extra knowing it was small and still did not have enough to make the 5th session. Im going to guess it takes about 8 gallons per 20 min session. I do not run out of gas in the Corvettes. Both of them can do 1 full day.
I have some footage from a go pro and will try to go over that today and get it online.
Thanks for reading.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
frenchsquared is offline   Reply With Quote
Old 02-20-2017, 11:28 AM   #2
flipstyledsm22
Let's go fishing!
flipstyledsm22's Avatar
Drives: a car with 8 cylinders
Great read! Glad you are having a blast and kicking ass!
"When choosing between two evils, I always like to try the one I’ve never tried before." Mae West 1892-1980
flipstyledsm22 is offline   Reply With Quote
Old 02-20-2017, 11:44 AM   #3
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
Sweet!
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 02-20-2017, 11:45 AM   #4
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
You will need some gas cans, we bring 6x5 Gal with us, that will hold 2 cars till lunch and then we go fill them, one more thing you may want to get some additive for octane, i like the extra power when you run 93+ not this 91 out west.
Old 02-20-2017, 11:50 AM   #5
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
Sounds like a blast.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 02-20-2017, 12:13 PM   #6
z28rox
Drives: 2015 Camaro Z/28
Since the driver of the GT4 car was a PCA instructor I am assuming he was driving a Porsche was it a 997 or Cayman?
z28rox is offline   Reply With Quote
Old 02-20-2017, 12:50 PM   #7
frenchsquared
I thought they were 911 so I guess 997. I will find a picture in a min
The Green one is below. This is the new on, first day or second day. The other GT4 was white but is the same car.
Old 02-20-2017, 12:58 PM   #8
L99CAMA2011
L99CAMA2011's Avatar
Originally Posted by frenchsquared View Post
It was not a Caymen. I thought they were 911 so I guess 997. I will find a picture in a min
GT4s are Caymans. Just under 390hp.
Old 02-20-2017, 01:08 PM   #9
Supercup
Life Is Short Enjoy It!
Supercup's Avatar
Drives: Former Owner 15 Z/28 #934
GT4 is top dog of the Cayman line up. It has 991 3.8L motor - 385 hp - 6 speed, same brakes and suspension as GT3. Best Cayman ever!
I have both the GT4 and the Z - they are both great cars - the GT4 is a scalpel while the Z is more of a hammer. The GT4, when set up correctly will out handle the Z due to lower weight and CG, but the Z will make it back up on the straights and on corner exits. So overall a very good match up.
GT4 Specs:
ENGINE TYPE:
DOHC 24-valve flat-6, aluminum block and heads, direct fuel injection
Displacement:
232 cu in, 3800 cc
Power: 385 hp @ 7400 rpm
Torque: 309 lb-ft @ 4750 rpm
TRANSMISSION:
6-speed manual
DIMENSIONS:
Wheelbase: 97.8 in
Length: 174.7 in
Width: 71.5 in Height: 49.8 in
Curb weight: 3050 lb
C/D TEST RESULTS:
Zero to 60 mph: 4.1 sec
Zero to 100 mph: 9.0 sec
Zero to 150 mph: 22.9 sec
Rolling start, 5-60 mph: 4.7 sec
Top gear, 30-50 mph: 6.8 sec
Top gear, 50-70 mph: 6.0 sec
Standing ¼-mile: 12.3 sec @ 117 mph
Top speed (drag limited, mfr's est): 183 mph
Braking, 70-0 mph: 151 ft
Roadholding, 300-ft-dia skidpad: 1.01 g
Supercup is offline   Reply With Quote
Old 02-20-2017, 01:20 PM   #10
All2Easy
Drives: 2015 Z/28 #997 Gone 2019 SS 1LE
Nice! Well done OP!
All2Easy is offline   Reply With Quote
Old 02-20-2017, 01:56 PM   #11
frenchsquared
Thanks for the info on the Porsche. I can ramble on about Corvettes but I don't know much about Porsche. I know if its a GT3 or GT4 its a bad ass car.
Old 02-20-2017, 01:57 PM   #12
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Well done. Enjoy the read.
The Z/28 is a sweet track car. Enjoy and welcome to HPDE's!
Mods:
Old 02-20-2017, 02:01 PM   #13
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
The track is an addictive place! I too loved mine stock, but the track also brings out the mods in us! Coil overs going in today
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 02-20-2017, 02:12 PM   #14
frenchsquared
I kinda made a video... I will get better at videos, care more about driving.
