Old 02-20-2017, 03:52 PM   #1
SergioSS
SergioSS's Avatar
Drives: Summet white , Camaro 2SS 2013
Cam for a l99 camaro 2SS
What's a good cam for my 2013 l99 ? I wanna see some good gains I've seen many cams out there make some great power, but I'm not sure which one to choose from any suggestions Also I don't want a crazy expensive cam a pretty cheap cam that'll do great power . Oh and also what else would I have to upgrade ? I know the valve springs And what else ??
Mods / K&n cai , Kooks Lt headers with high flow cats , flow master axle back,
SergioSS is offline   Reply With Quote
Old 02-20-2017, 04:03 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Talk to GPI. Experts on VVT cams. Rhino79 (Ryan) is the goto guy. Best to call them...
BTW, cheap and power usually don't mix ;o). Lot of things to update when you go for power... they'll setup a kit for you based on your goals...
http://gwatneyperformance.com/
-Don
747 RWHP 794 RWTQ
Old 02-20-2017, 07:17 PM   #3
Strong66
Drives: 2013 SS whipple
Depending on the cam you may need a torque converter, and they can be budget unfriendly.
Strong66 is offline   Reply With Quote
Old 02-20-2017, 08:22 PM   #4
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
What Don said. Cheap and power don't go together. You'll find out soon enough
camarosspower is offline   Reply With Quote
Old 02-20-2017, 08:45 PM   #5
Hulk
Hulk's Avatar
Drives: 2011 Synenergy Green 2SS/RS
-Don
That says it all. Just got all my stuff installed and fired up. Best upgrade yet.
2011 Synenergy Green 2SS/RS Automatic.
Hulk is offline   Reply With Quote
Old 02-20-2017, 09:20 PM   #6
SergioSS
SergioSS's Avatar
-Don
Well I don't mean cheap cheap lol I meant like a good cam for a good price
Old 02-20-2017, 09:39 PM   #7
Bo White
Bo White's Avatar
If you can only afford one mod at a time. Stall converter first.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 02-20-2017, 09:40 PM   #8
SergioSS
SergioSS's Avatar
So i might need a torque converter ? Do I upgrade it first before I get a cam
Old 02-20-2017, 09:47 PM   #9
camarosspower
If not planning on forced induction then I would do gears,stall, then cam
Old 02-20-2017, 09:49 PM   #10
hammdo
hammdo's Avatar
Depends on what your goals are. I have the VVT SS1, but I don't drag race. If you don't plan on road racing at all, the converter is first, that will open up your cam options as Bo stated...
Me, I road race so a converter is a no go. SS1 is a street friendly cam and I can still take it out for a 30 minute road race session and trans temps are excellent, because I didn't upgrade the converter...
Drag, get the converter first. Wakes up the car...
(I'm FI BTW...)
-Don
747 RWHP 794 RWTQ
Old 02-20-2017, 10:45 PM   #11
SergioSS
SergioSS's Avatar
(I'm FI BTW...)
-Don
What gains did yu make with the SS1 cam ? And so you had not had any problems with the stock converter ? Btw I seen Yu have 3.91 gears would I have to upgrade that as well sorry I'm still learning a whole lot
Btw awesome build on your camaro !
Old 02-20-2017, 11:55 PM   #12
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
http://www.camaro5.com/forums/showthread.php?t=365406
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 02-20-2017, 11:58 PM   #13
hammdo
hammdo's Avatar
Thanks!
I'm FI so I now have 3.45s. I did it all at the same time. Ryan can tell you the typical gains. No issues with the converter after it broke in. It does push just a little when new.
It is a great na cam if you want stock drivability. SS2 would be pushing it on the stock converter.
Don't have to have gears unless you are not going FI. 3.91s on the auto is awesome as long as you stay na.
-Don
747 RWHP 794 RWTQ
Old 02-21-2017, 07:54 AM   #14
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
You're gonna need to upgrade a pretty decent amount which normally comes packaged together for most cams.
Including labor and a good tune, look to spend at least $4k - $5k
Dmpsix is offline   Reply With Quote
