02-20-2017, 10:13 PM | #1 |
Drives: 2015 SS 1LE Join Date: Jan 2017
New cam and exhaust. will it start ?
Car has a KN CAI and is all stock.
Getting ready to order a set of Long tubes, exhaust, cam, ported TB etc... Once I put all this in will the car start, run, and drive ( Freeway speeds ) safely without a tune ? Im planning on getting it tuned but will I be able to drive it to a shop for some dyno time ?
2015 Velvet Blue 1LE
02-20-2017, 10:30 PM | #2 |
Drives: 2013 Dusk SS, 2017 Pacifica Join Date: Feb 2017
Don't be tempted to run it hard and you'll be fine. As long as you make sure everything is sealed and hook up ALL sensors (I always forget one). Unless it's a not so mild cam, I can't imagine it causing problems.
02-20-2017, 10:30 PM | #3 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Should start.. drive it to tuner is fine..just baby it though.
02-20-2017, 10:31 PM | #4 |
I know for my car, builder said it barely cranked over.
02-20-2017, 10:36 PM | #5 |
Drives: 13' 1LE Join Date: Apr 2012
Mine ran ok, but idle was weird and car was dying everytime I would push the clutch. Ran like a POS. It even ran like that with a "base tune" from a known seller. I siwtched to a real tuner like Pat G and it ran perfect on "his 1st base tune" (email tune with autocal).
It will run like shittt
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
02-20-2017, 10:59 PM | #6 |
Ben Rakers
I wouldn't risk it personally. I would find someone with a trailer or get a flatbed to tow it over if you can afford it.
2011 Camaro 2SS/RS K&N Blackhawk Cold air intake, Hawk Performance Ceramic pads, BAER drilled and slotted rotors, Side louver black faded inserts, Hurst Short Throw Shifter, BMR Trailing Arms, Elite Engineering Catch Can, MSD Spark Plug Wires, Texas Speed 1 7/8in Headers and cat back, High Flow Cats, 3 inch X-Pipe, Speed Dawg shift knob, Tuned by Nickey. And oh, its My first car.
https://www.youtube.com/channel/UC_L...5jF6EQEoKDNQ2g |
02-21-2017, 02:12 AM | #7 | |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
That's a lot of changes at once. It would be a shame if the car decided not to handle it after you sink that much into it.
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
02-21-2017, 04:14 AM | #8 |
Drives: 2010 SS Join Date: Nov 2009
Your initial startup will have the car in Open loop. That will be rough at first, and depending on your cam size, you may have too much air flow. As stated above... it may not stay cranked.
Once your car enters Closed loop, you should be ok to a point. You're ECU will make adjustments accordingly. But if you've ever seen a scanner right after a swap like that, your Fuel Trims are going nuts. It's having to adjust for an increase of air that it thinks shouldn't be there. If you gas it too hard (enough to enter power enrichment) you'll most likely lean out. Ain't nobody got time for that! I personally (if I didn't have tune software) would only feel safe driving it straight to the Tuner, and would only do that if I had my scanner hooked up so I could monitor everything.
2010 Camaro SS
Night Furry Cam Vararam Intake Custom Long Tube Headers - Straight Pipes Self Tuned with HP Tuners |
02-21-2017, 07:09 AM | #9 |
Anyone have luck with a mailed tune in a sct or diablo for something like this ?
Thinking of a ts stage 3 cam. Long tubes/full exhaust, Ported tb. I originally was planning on doing the exhaust then just paying a local shop to install the cam and tune it but the 2 local guys I know of don't return mesages ( pm, email, or phone).
02-21-2017, 07:28 AM | #10 |
Drives: 2011 Synenergy Green 2SS/RS Join Date: Jan 2011
I went with the GPI VVT SS3 cam, Ported heads, intake manifold tube mod, ported throttle body. Everything I needed was in the boxes. They sent me the initial tune. I turned the key and it fired up like normal only louder and then the nice cam sound came in. Still running it on the initial tune. I talked with Ryan to get what I needed. Awesome Customer support!
Take pictures and when you disconnect anything put blue painter tape on it and write on it so you know where it goes. The blue tape is easy to spot so you do not miss something.
2011 Synenergy Green 2SS/RS Automatic.
02-21-2017, 08:07 AM | #11 |
Im good with the actual install work. Not worried about that part at all.
Just new to needing a computer to make it run. I was just gonna pay the shop to install the cam so they could tune it at the same time. Guess Im just old.
02-21-2017, 08:43 AM | #12 |
You should have no trouble getting some of the sponsors on here to set you up with a tune based on your setup and get it to you on a hand held to load it up.
2010 Camaro SS
02-21-2017, 09:19 AM | #13 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
It's going to be tempermental, but it will run. I would contact JDP in Murray pretty quickly as their dyno fills up quickly. They are the ones who tuned mine the first time with the basic boltons, and the second time with the cam. Very happy with their tunes.
02-21-2017, 09:25 AM | #14 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
dynoSteve...seriously...why would you sink all the $$ into a car that run's on a computer and no tune? peace out...
