Old 02-20-2017, 11:26 PM   #1
ZOOMSS
ZOOMSS's Avatar
Drives: 2010 Red Jewel 2SS/RS
1LE kit missing springs?
Ok so I ordered the 1LE kit for my 2010 SS from Ed Rinke Chevy, long story short I just broke open the boxes and to my surprise, there are no springs, or stops. Is the kit supposed to come with those like it shows in the pictures or was I mislead by the photos?
ZOOMSS is offline   Reply With Quote
Old 02-21-2017, 12:50 AM   #2
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
If I remember from my studies on this forum, the SS and 1LE springs are the same.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 02-21-2017, 06:38 AM   #3
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
Springs do not come with the kit.
justjoshin is offline   Reply With Quote
Old 02-21-2017, 07:03 AM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
1LE springs are SS springs. But you are right 1LE kit does show springs.
CamaroDreams76 is online now   Reply With Quote
Old 02-22-2017, 11:32 AM   #5
JusticePete
Drives: Camaro Justice
Use your SS springs as they are the same as the 1LE springs.
Old 02-23-2017, 08:17 AM   #6
justjoshin
justjoshin's Avatar
I was told that the picture showing the kit with springs is actually the V6 kit. My kit did not come with springs and I swapped the stock springs with 1" Hotchkis drop springs at the time of install.
