Old 02-21-2017, 06:00 PM   #1
Skullcandy
Skullcandy's Avatar
Drives: 2013 camaro 2ls
Axle nut
I have a 3.45 diff that I've been trying to put in but I have an issue with getting my damn axle nuts off. I've heated them I've tried everything. I'm about to just buy all new knuckle assemblies. I'll add a picture of what I'm talking about. I don't want to melt it off ... yet. But i need some suggestions here.
Skullcandy is offline   Reply With Quote
Old 02-21-2017, 06:02 PM   #2
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Use a long breaker bar.
camarosspower is offline   Reply With Quote
Old 02-21-2017, 10:05 PM   #3
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Heat it tell it's pretty much glowing then try
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 02-22-2017, 01:24 AM   #4
FunkedOut
FunkedOut's Avatar
Drives: Black 2010 SS
pbblaster overnight
heat and impact wrench
FunkedOut is offline   Reply With Quote
Old 02-22-2017, 01:39 AM   #5
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
How long was that thing in the swamp?
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 02-22-2017, 08:29 AM   #6
hesster
hesster's Avatar
Drives: '10 T/A Conv, '10 2SS, '77 SE T/A
Blaster penetrant, let it soak for a day, and maybe the only hope is a Kahuna Impact with the correct 36 mm axle nut socket. It looks totally fused on, so you may need to use a air chisel and split the nut as a last resort.
hesster is offline   Reply With Quote
Old 02-22-2017, 08:44 AM   #7
Skullcandy
Skullcandy's Avatar
Axle nut
I've soaked for about a month and have used a 6ft bar. No luck. I actually start lifting the cat off the lift when my buddy helped. My car is from Detroit so the winters and all the salt there obviously didn't help this poor little nut. I've been trying to do this swap for about a year but this nut is the reason I can't . I'll just take it into work and cut it off probably or take the whole knuckle off and go from fhere
Old 02-22-2017, 09:29 AM   #8
camarosspower
Try Kano penetrating oil. This what mechanics in the refineries use for the big bolts that won't come loose
Old 02-22-2017, 09:33 AM   #9
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
cold chisel, hold it with channel locks so you can hit it with a small sledge hammer, line up on the nut(wear safety googles plz) and go for it and try splitting...some times don't even need to go all the way for it to break...seriously doubt this could twist the end off the axle but either way the axle threads r prob trashed so go find a good replacement axle FIRST!
Hopefully the hub isn't trashed due to the heating etc...may want to invest in one of those to...good luck..peace out...
Old 02-22-2017, 11:30 AM   #10
JusticePete
Drives: Camaro Justice
First get in there with a wire bruch and clean away the corrosion until you get to shiny metal. Once cleaned up, start hitting it with daily dose of a penetrating oil. After a week, heat and try it with a big breaker bar of strong impact. If it doesn't come loose, soak it again and repeat.
Old 02-23-2017, 10:23 AM   #11
Abdi
Drives: 2013 1LE
This is probably the best penetrant ever.
http://www.kanolabs.com/
Kroil spray is magic I swear. Amazon has it, good luck!
Abdi is offline   Reply With Quote
Old 02-23-2017, 07:45 PM   #12
Skullcandy
Skullcandy's Avatar
Axle nut
That Kroil spray is all I use at the shop and it does amazing things but apparently my axle nut was put on my the lord himself and is impervious to everything. I cleaned it and what have you but I'm pretty sure they are fused together. I'll probably take it to the shop on Monday and hit it with the heat hard. I'm getting to the not caring point and will do what it takes to get this pig out lol. I'll keep it updated. I have axles and hubs and everything for my swap.
