Old 02-22-2017, 12:01 AM   #1
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Restoring aluminum
My car had to be parked outside over winter and now the aluminum is corroding. The trans, crossmember and alt/ps brackets are "dusting". Just wondering what you guys do to fix it. It's not real bad, seems to just wipe off by hand, but can't get my fingers into all crevices. Any advice?
Caswell239 is offline   Reply With Quote
Old 02-22-2017, 08:34 AM   #2
BRZN
BRZN's Avatar
Drives: 2012 1LT
All those pieces are cast aluminum. You'll not want to get any type of paste of liquid polish onto them, you'll never get the polish off.
Try in an inconspicuous place, a cheap, acid type, caustic wheel cleaner from the box store chains. You'll need to agitate the product on the metal, so brushes are going to be needed. Bottle type brushes, Daytona Speed Master Wheel Brushes, Trim and Lug Nut Brush, tooth brush, etc...
I don't believe you'll be able to get the pieces into a back to new appearance, but most of the white oxidation should come off.
BRZN is offline   Reply With Quote
Old 02-22-2017, 09:11 AM   #3
O.F.
O.F.'s Avatar
Drives: 2015 BLK/BLK 2SS/RS MN6
You might experiment with some 0000 steel wool. I've used it on aluminum wheels before with great results.
O.F. is offline   Reply With Quote
Old 02-22-2017, 10:42 AM   #4
BRZN
BRZN's Avatar
Drives: 2012 1LT
The steel wool will polish spots it's rubbed on. If you can't get into all the little crevices with your fingers the pieces will no longer have an even appearance.
Old 02-24-2017, 09:46 PM   #5
Viczl1
Viczl1's Avatar
Drives: 2019 ZL1
Steel wool will get logged into the aluminum DONT DO IT.
2013 Inferno Orange
A6, bone stock
Viczl1 is offline   Reply With Quote
Old 02-25-2017, 05:20 AM   #6
BRZN
BRZN's Avatar
Drives: 2012 1LT
Good point. I'd not thought of that of that one. They're two dissimilar materials. If the steel gets into the aluminum you'll begin to not only see the oxidation from the aluminum, but rust from the steel.
Old 02-25-2017, 06:26 AM   #7
Ponchonutty
Ponchonutty's Avatar
Drives: 2012 SS L99 Converible
Spray it with some aluminum cleaner, hose it off and dry it as fast as you can. Then spray it with wd40 or other water repellent. It will look good again
Ponchonutty is offline   Reply With Quote
Old 03-03-2017, 07:20 AM   #8
gringo
gringo's Avatar
Drives: Camaro V6
Blast it with soda. Get a portable sandblaster/media blaster at Harbor Freight and load it up with common baking soda. The aluminum will look like new after that and the soda will help protect it from oxidizing again. Works like a charm!
gringo is offline   Reply With Quote
Old 03-03-2017, 05:18 PM   #9
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
Possibly Gringo would like to help you clean up all the mess the soda is going to make everywhere else on your car. Assuming you are not going to take the parts off the car.
stratman2SSRS is offline   Reply With Quote
