Old 10-22-2009, 12:40 AM   #1
EAkrish
Scout Sniping
EAkrish's Avatar
Drives: 2010 Ford F150 Lariat SuperCrew
Send a message via AIM to EAkrish
Exclamation 160 Degree Thermostat and Car Issues....
I installed a 160 degree thermostat yesterday night. It is working very well with my tune. Tonight I was driving home and my DIC displayed a message that said " AC turned off due to high engine temps". I was like holy SH&^! Anyway I shut the car off and turned it back on seeing if this would correct it. No dice. I pull over and feel around the engine bay, NOT HOT! I start to drive home again and notice the engine coolant temp was at --- degrees, and the gauge was all the way cold. I finally made it home, shut the car off and unplugged the ecu. Plugged her back in, started her up and everything was back to normal. Any ideas????
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!!
Now I drive a F150 Supercrew
EAkrish is offline   Reply With Quote
Old 10-22-2009, 12:50 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
gremlins in that car.
Old 10-22-2009, 12:52 AM   #3
coolman
Guest
I thought I saw another thread about this. Search. I think it said you had to tune the ecu for that mod.
coolman is offline   Reply With Quote
Old 10-22-2009, 12:52 AM   #4
EAkrish
Scout Sniping
EAkrish's Avatar
it is tuned.....
Eric
Old 10-22-2009, 12:53 AM   #5
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Nope, no tune needed, at least no error. Maybe not be ideal, but mine has been in a week with no tune, no issues, and a weekend driving in triple digits in the desert.
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 10-22-2009, 12:58 AM   #6
2SSRS@Gen5diy
I did something one day and did not get one of the new MSD wires on all the way, and drove to work and back that way and on the final 2 mi the car started to run bad and the
DIC displayed a message that said to service the car and it stop running and then i restarted the car drove home and fixed the wire and have not had that problem any more.
Old 10-22-2009, 12:58 AM   #7
EAkrish
Scout Sniping
EAkrish's Avatar
Any ideas what could have happened? Oh I also gutted the factory cats. Don't think that is the issue though
Eric
Old 10-22-2009, 12:59 AM   #8
coolman
Guest
Is the temp sensor close to where you were working? maybe you got the wire loose to it.
Old 10-22-2009, 01:01 AM   #9
EAkrish
Scout Sniping
EAkrish's Avatar
I don't think so, after I reset the ECU it is all normal
Eric
Old 10-22-2009, 01:05 AM   #10
2SSRS@Gen5diy
YOu have to edit the P0128 code under the Engine Diagnostic>DTC tab. Turn the code to #3 with no report.
If the ECM does not see at least 167* over a certain duration it triggers that code and turns the coolant gauge offon the cluster.
Old 10-22-2009, 01:07 AM   #11
EAkrish
Scout Sniping
EAkrish's Avatar
are you sure about this? I drove with it for two days before this happened
Eric
Old 10-22-2009, 01:08 AM   #12
2Tightwads
Banned
Drives: 2002 LS1 swapped into a 1994 Z
Ditto! Do us a favor and check connection. Then confirm your actually reading something other than --- engine temp. as well.
2Tightwads is offline   Reply With Quote
Old 10-22-2009, 01:08 AM   #13
2SSRS@Gen5diy
If that was to me that is from HP tunes
Old 10-22-2009, 01:08 AM   #14
EAkrish
Scout Sniping
EAkrish's Avatar
Also is there any harm to the motor from running your engine cooler? That kinda sounds like a dumb question
Eric
Tale of two Corvettes... My old C5 and the C6 that replaced it. Cmicasa the Great XvX General Automotive + Other Cars Discussion 12 02-09-2010 12:06 AM
F/S: 1996 Collector's Edition LT4 VIN #00003 (WA State) Teddydog Autos For Sale / Wanted 9 01-05-2010 02:50 PM
The first 4 months of owning my car - pics / vids included Crowley 5th Gen Camaro SS LS LT General Discussions 19 09-30-2009 02:05 PM
160 degree thermostat rforbes Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 07-07-2009 03:34 AM
