Old 02-24-2017, 06:12 PM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
Fore vs squash fuel system for 1k whp
Which to pick and why
hou30guy is offline   Reply With Quote
Old 02-24-2017, 09:08 PM   #2
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
People will likely suggest what they have, both work well. For the price and simplicity I like the AGP/Fore system
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
Old 02-24-2017, 09:30 PM   #3
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
I don't have personal experience with squash. I do have the Fore triple pump setup and it works really well. Very high quality & all the fuel you'll ever need.
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian
LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads
ProCharger F1-X
Nitrous Outlet Direct Port
Fore Innovations Triple Pump on E85
Alky Control Meth Injection
ProEFI ECU
Stainless Works 2" Headers with Corsa 3" Exhaust
RPM 4l80e with Jakes Transbrake
BMR Everything with 15" Conversion
Zl1 Front Brakes & Carlyle Racing Rear Brake Kit
Weld Wheels
moiy1983 is offline   Reply With Quote
Old 02-25-2017, 01:43 AM   #4
hou30guy
Agp, is both feed and return 8an or only 8an feed and 6an return
Old 02-25-2017, 06:26 AM   #5
Glushenij
Glushenij's Avatar
Drives: 2014 Camaro 2SS 1LE
AGP use stock line as return! I run AGP triple with rails and 1400cc inj
AGP TT 807whp 811wtq 13.46psi E85+methanol
Glushenij is offline   Reply With Quote
Old 02-25-2017, 02:22 PM   #6
hou30guy
Does agp includes rails and e85 sensor and filter for e85
Old 02-25-2017, 02:23 PM   #7
hou30guy
And 6an sufficient for the return
Old 02-25-2017, 06:11 PM   #8
hou30guy
Did it come with a flex fuel sensor or just the fittings for it
Old 02-26-2017, 12:51 AM   #9
Glushenij
Glushenij's Avatar
Rails and flex optional! I did got rails and flex sensor and injectors from them! Everything fit without modification and come with all hardware ( u can see rails in pic 3)
Old 02-27-2017, 09:10 AM   #10
CGbambam
Drives: 2011 Camaro 2SS
Fore FTW
CGbambam is offline   Reply With Quote
Old 02-27-2017, 11:08 AM   #11
hou30guy
I think im gonna do a fore hat and pump with a vaporworxs pwm controller, around 1300 total for a returnless system,
Old 07-16-2018, 07:27 AM   #12
PFL
PFL's Avatar
Drives: Camaro SS
have you installed any fuel pressure sensor for datalog? I do not see this in the fore
PFL is offline   Reply With Quote
Old 07-16-2018, 07:58 AM   #13
hou30guy
I ended up going with agp fore with dual pumps, the regulator has that info, set it to 58psi and for every lb of boost it goes up 1 psi automatically
Sent from my SM-N950U using Tapatalk
