Old 02-26-2017, 06:40 AM   #1
Ponchonutty
Ponchonutty's Avatar
Drives: 2012 SS L99 Converible
Brembo brake service questions
I need to change the pads and rotors on my SS with the base Brembo brakes. I see people saying to ditch the factory lines at the calipers for stainless. Is there much improvement to make this required? I plan on using Alien rotors and Hawk yellow pads when I do get these changed. Thanks for your input
Ponchonutty is offline   Reply With Quote
Old 03-01-2017, 12:41 PM   #2
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
see this thread http://www.camaro5.com/forums/showthread.php?t=116867
camguynj is offline   Reply With Quote
Old 03-01-2017, 02:34 PM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
If you don't already have one get a vacuum pump and after replacin the rotors/pads do a complete bleed. Makes a major diff and if after you still need more then put in the stainless...but I've read that unless you are trackin the car weekly no need...spend $$ on makin more power! peace out...
Old 03-02-2017, 02:03 AM   #4
Ponchonutty
Thanks guys. It looks like I will just hold off since I just do summer cruising with this
Old 03-02-2017, 10:36 AM   #5
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
I track a bit, so added stainless lines last year. Pedal felt a bit firmer under hard pressure. For the cost (@$120), it was worth it for me. Easy swap, you can do it with the bleed in about two hours.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
