Old 03-01-2017, 08:49 AM   #1
Coreymottes
Drives: 2010 ABM 2SS
Question About Mid Pipe
I have a stock 2010 camaro SS L99 with borla atak catback. It just isnt loud enough so I bought a JBA Catless midpipe. I understand this will set off a CEL. I do not plan on getting a tune which is why i didnt buy LTs but will this change the way my car runs? Either stay the same, too rich, too lean?
Coreymottes is offline   Reply With Quote
Old 03-01-2017, 11:14 AM   #2
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Once it throws a CEL, the car will lean out and automatically try to correct which will make it run too rich. You most likely will need a tune to correct that.
SSEssence is offline   Reply With Quote
Old 03-01-2017, 01:18 PM   #3
Dave@Sturgiscamarorally
Dave@Sturgiscamarorally's Avatar
Drives: 2010 ABM 1SS
You will kick the light and it will through off the fuel tables until it is corrected or tuned out. You could use a spacer to pull the O2 out of the flow. I bought these for a quick fix until I was able to get a tune done. Ran for about a year and a half with no issues.
http://www.bigdaddiesgarage.com
2010 Aqua Blue 1SS
KWC 3pc forged, Seibon hood, ZL front end, MGW, ARH full exhaust w/ Doug Thorley axle back, BTR4, Roto-fab, LSXR 102, NW 102, 3.91s
Dave@Sturgiscamarorally is offline   Reply With Quote
Old 03-01-2017, 02:03 PM   #4
Coreymottes
I actually just received those Mini CEL fix things from Big Daddies Garage today but the midpipe wont be here until next week. So running these will prevent my car from running too rich/lean?
Old 03-01-2017, 02:07 PM   #5
SSEssence
Instagram: Sangstah
if you don't throw a check engine light, you won't have to get a tune.
Old 03-01-2017, 04:09 PM   #6
Coreymottes
Awesome, thank you
Old 03-01-2017, 04:26 PM   #7
dontlift19
Drives: 2012 2SS/RS
I had mine on for about a year and never got a cel. The car ran fine and I didn't use the o2 spacers.
dontlift19 is offline   Reply With Quote
Old 03-04-2017, 11:52 AM   #8
it may run a touch rich, I could smell it a bit more when standing at the tips but nothing to cause a CEL.
2010 Aqua Blue 1SS
Old 03-04-2017, 12:33 PM   #9
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
If you get a CEL with code(s)P04xx it coming from the rear O2 sensors and your fuel trims won't be affected. Those codes merely indicate that your cats aren't working effeciently ... da
camguynj is offline   Reply With Quote
Old 03-04-2017, 02:44 PM   #10
14blackwidowls3
Drives: 2016 Camaro 2ss
I have slp loudmouths on my 14 ss and it's not loud enough either. I'm going to instal high flow cats to keep from having the cel. And it'll be louder. Plus a possible long tube headers set up also. But I want to do electric cutouts for if I just wanna be stupid loud lol
14blackwidowls3 is offline   Reply With Quote
Old 03-05-2017, 12:25 AM   #11
Having high flow cats will not prevent the CEL. Only way to avoid it is to use the spacers or have the O2s tuned out.
2010 Aqua Blue 1SS
2010, camaro, exhaust, l99, midpipe
