Old 03-02-2017, 03:28 AM   #1
the ron
Drives: Vxr8
Zl1 fuel pump
How much power can the standard pump handle with id850 injectors?
the ron is offline   Reply With Quote
Old 03-02-2017, 07:19 AM   #2
Dwright
Drives: 2011 Camaro 2ss
600 to 650 max wrhp. Would max it out.
Dwright is offline   Reply With Quote
Old 03-02-2017, 10:17 AM   #3
TitusSS
Drives: ECS Supercharged 2010 SS
I got 670 with ID 850's, a Zl1 pump, BAP, meth and ADM FPCM. YMMV.
TitusSS is offline   Reply With Quote
Old 03-02-2017, 11:26 AM   #4
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Depends on the power adder also
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 03-02-2017, 11:32 AM   #5
hillshooter
Drives: 2015 Camaro SS commemorative
I got over 700 but we were relying on methanol too much and it was dangerous.
hillshooter is offline   Reply With Quote
Old 03-02-2017, 11:38 AM   #6
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
700 with boost a pump or a fpcm from adm would be my max
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 03-02-2017, 01:08 PM   #7
the ron
Drives: Vxr8
Currently running out of fuel at 5.5k rpm but only have 52lb injectors at the moment got zl1 pump just about to upgrade to id850 injectors hopefully that sorts it out
Old 03-02-2017, 01:27 PM   #8
blake2010ss
may, if not, look into adm fpcm.
1093/1066
Old 03-02-2017, 01:33 PM   #9
the ron
Drives: Vxr8
Where about does this plug into at that price might as well give it a try as well ?
Old 03-02-2017, 01:35 PM   #10
blake2010ss
my shop put mine in, so im not 100% on this and a shop may give a better answer, but i want to say its located either underneath the rear passenger seat or behind the trim panel by the rear passenger seat
1093/1066
Old 03-02-2017, 01:40 PM   #11
JusticePete
Drives: Camaro Justice
650 safely and after that...
Old 03-02-2017, 06:07 PM   #12
bayarea408
bayarea408's Avatar
Drives: T
adm FPCM is behind the rear passenger side wall cover on the right. you pry that side cover off and there sits the OEM unit. You just swap the ADM unit right in.
bayarea408 is offline   Reply With Quote
Old 03-02-2017, 10:37 PM   #13
blake2010ss
Atleast I was in the right vicinity lol
1093/1066
Old 03-02-2017, 11:55 PM   #14
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
I did 650 on e85 with 1000cc injectors and adm fpcm. I'm going to dual pumps next week
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
