Old 03-02-2017, 01:01 PM   #1
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
BMR Toe rods or ZL1/1LE
Hey guys,
So I've installed upgraded trailing arms and subframe bushings, but I still have some rear end wiggle with just regular bolt-ons. I'd like to upgrade my toe rods, but I'm having a hard time deciding which to go with, either the BMR non-adjustables, or the ZL1/1LE.
I can find the BMRs for about $100, but I'm having a hard time finding the ZL1/1LEs for anything less than $150.
I know the ZL1 rods are spherical, but is that worth another $50?
Will I regret going with the BMRs?
Car is mainly a DD...
Thanks!
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 03-02-2017, 01:08 PM   #2
JusticePete
Drives: Camaro Justice
For a DD, you want to stay with the OEM arms. OEM arms are designed to fold, they are sacrificial. If you get loose and kiss a curb on a rainy day, the arm bends to protect the sub=-frame. Install a tubular arm and the sub-frame brackets are the weak point. Replacing a toe link is cheap. Replacing a sub-frame $$$$$
Get a set of 1LE/ZL1/Z/28 toe links and a set of Z/28 trailing arms.
Old 03-02-2017, 05:29 PM   #3
LCPLPunk
USA-1
LCPLPunk's Avatar
I've got the Z28 trailing arms already, so it looks like the 1LE/ZL1/Z28 links are what I need then.
Thanks Pete!
Old 03-02-2017, 07:17 PM   #4
JusticePete
Thanks Pete!
How hard do you run?
Old 03-02-2017, 08:44 PM   #5
LCPLPunk
USA-1
LCPLPunk's Avatar
It's a DD with bolt-ons...370 to the wheels I'm guessing. Once I get back to the mainland I plan on getting 3.91s and upgrading from 275 to 295 rear tires.
Old 03-02-2017, 08:45 PM   #6
JusticePete
Your parts list is good to go then.
Old 03-05-2017, 05:08 PM   #7
eastwood
eastwood's Avatar
Drives: Blown 2010 Orange camaro ss/rs
What would you rec justicepete for a 2010 camaro ss
I am going to be pushing about 650 rwhp. Iam putting a complete zl1 hd driveline in
Havnt done anything to rear bushing,connector and subframe
Thanks
eastwood is offline   Reply With Quote
Old 03-07-2017, 05:04 PM   #8
JusticePete
Thanks
Spirited Street, Drag or Road Course?
