Old 03-03-2017, 11:13 AM   #1
Arman
Drives: 2014 Camaro SS
Service stabilitrak problem.
Hello again forum, I posted about a week ago, thought the problem was fixed, but it came back.
Ill try to make this short.
2 weeks ago, installed a new CAI filter
1 week ago, at startup. Car ran rough and underpowered. Service stabilitrak came on.
Cleaned MAF, did fuse pull 5 and 20 since I thought it was running lean.
After that car ran good and strong for about 5 days.
This morning as I turned the car on, started fine, but car exhaust sounded weaker.
10 minutes into my commute, service stabilitrak came on with CEL and went underpowered again.
Last week when I looked at codes it was P0308 which was cylinder 8 misfire. I am at work right now so I don't have my code reader and can't check.
People are talking about the battery. The battery is about 3 years old and its the original. Granted I keep it on a tender if I'm not driving for over 2 days. But the battery will stay at 14.8 to 15.1 volts. So I'm assuming its losing its charge.
I have checked the wires to the cylinder and everything looks correct.
Let me know if anyone needs pics of anything, I can get that. I just want to fix this.
What boggles my brain is that this morning it came on in the middle of my commute while I was doing 65 on the highway.
Thank you in advance.
Arman is offline   Reply With Quote
Old 03-03-2017, 12:31 PM   #2
mmaattppllaayy
Drives: '10 Camaro 2SS
Wheel speed sensor or bad plug/coil/wire on #8. Go to autozone and rent the expensive scan tool that checks abs codes and see what the stabilitrak code is. It's around $250 to rent the tool but get it back when your done.
mmaattppllaayy is offline   Reply With Quote
Old 03-03-2017, 03:30 PM   #3
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Very handy tool to have .......INNOVA 3160
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 03-03-2017, 05:38 PM   #4
Tje66
Drives: 2010 Camaro 2ss procharged
Stabiltrak
Change the coil pack. In that cylinder. And check the connection on injectors. I have chased the same problem and that was the fix
Tje66 is offline   Reply With Quote
Old 03-03-2017, 07:35 PM   #5
Arman
That's what I will do tomorrow. I will keep yall updated.
Old 03-05-2017, 04:23 PM   #6
Arman
So the problem went away when I went to dealership, so they could not diagnose it. I guess the moment it comes back ill have to take it.
Old 03-05-2017, 09:09 PM   #7
STALKER
STALKER's Avatar
Drives: 2023 Camaro ZL1 1LE
Thats always the way it goes lol.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler
2023 Camaro ZL1 / 1LE
Stock
STALKER is offline   Reply With Quote
camaro, cel, ls3, stabilitrack
