Old 03-04-2017, 01:23 AM   #1
yoinkster
Drives: Straight Bumblebee
Remote start problem
Hey guys,
I have a '15 2SS and have noticed a problem with the remote start.
Basically, it doesn't work.
I've had it work twice and I'm not sure what circumstances could've lead to it to decide to work and I'm wondering if anyone can help me with some experiments of their own or some advice.
I once got it to work via the onstar app a few weeks agoremote sta.
I got it to work again once today with the following conditions:
When the car was only "single locked" (had only pushed Lock on the fob once and the horn didn't go BEEP) it did not work.
I then "double locked" it (where it locks and then the horn goes BEEP) and it worked. Once. I then let the car run for ~5minutes and stopped it. I then unlocked the car but didn't get in. Double locked it again and it did NOT work again.
Does it sound like I have a problem with my remote start or are there a special conditions to make it work?
I had previously had a problem with the battery (it kept dying, I have another thread about that if you'd like to read up on that if you think it's part of the problem with this) that I thought had been resolved. The dealership in that instance replaced the battery for me and I haven't had it go flat over a weekend since. But maybe somehow my battery is constantly too flat to allow it to remote start? Is that a thing? Is there anyway I can check how charged the battery is to check to see if this is still a problem?
Thanks for your time and experiments if you do any with your own remote start to try to help me figure out if there are any special conditions I have to meet for it to remote start.
yoinkster.
yoinkster is offline   Reply With Quote
Old 03-04-2017, 01:39 AM   #2
Candr3535
Candr3535's Avatar
Drives: 2013 ZL1 Triple Black Vert M6 #5591
You must click the lock button twice then hold the remote start button down for a few seconds. If the car doesn't lock it won't start. Also the car can only be started twice in a row with out having to start it with the key. Good luck hope that helps
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice..
Candr3535 is offline   Reply With Quote
Old 03-04-2017, 02:33 AM   #3
yoinkster
Thanks for the reply, I'll give that a few tests and see what results I get.
Out of interest, is there any way to set the car to double lock with a single press of the lock button? Pushing a button twice is far too cumbersome for me!
Old 03-04-2017, 08:39 AM   #4
JamesMyBoy
Drives: 2014 2SS/RS
Hmmm...
I push my lock button once, then hold down the start button until I hear the relay pickup on the car. Otherwise, I just hold the start button down (when out of ear shot) three or four seconds. Works every time.
JamesMyBoy is offline   Reply With Quote
Old 03-04-2017, 02:05 PM   #5
bayarea408
bayarea408's Avatar
Drives: T
If you have a check engine light, doors unlocked it wont work.
bayarea408 is offline   Reply With Quote
Old 03-04-2017, 02:16 PM   #6
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 03-04-2017, 08:52 PM   #7
yoinkster
Originally Posted by JamesMyBoy View Post
Hmmm...
I just did a little experiment. I took the car out for a longer drive than it normally gets. Parked it up. Single locked it and then an hour or so later, tried to remote start it. It failed. I then double locked it and tried and it worked!
That gives me the impression that it might be still related somehow to the battery but yet it's weird mine won't do it on single lock like yours does
No check engine light and the car was locked, it's a pretty healthy car .... apart from the battery issue and now this
Originally Posted by sherob View Post
yeah I put pluto because it told me that "US" was too short, I'm a comedy genius like that you see ... honest. ahem.
Old 03-05-2017, 08:35 AM   #8
JamesMyBoy
Drives: 2014 2SS/RS
Note that there is only a couple seconds allowed between the first push of the lock button and the pressing of the start button. Seems like it's only 2 or 3 seconds, otherwise it won't work. I'm sure this is to prevent unwanted starts.
Can't imagine why it would take two pokes of the lock button for this to work, but stranger things have happened I'm sure :-)
Old 03-05-2017, 10:20 AM   #9
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
I only have to press the lock button once.
Maybe change the battery in the remote?
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 03-05-2017, 02:49 PM   #10
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
My 2015 has always been finicky too. I've used the remote start dozens of times but there are days when it just won't work. I did notice that if you're in the same garage with the car, i.e. standing next to it, it doesn't seem to work as well as being a little farther away.
I seem to have always pressed it twice and heard the horn blow before it worked. It was intermittent from day one so I never suspected the fob battery.
Moto-Mojo is offline   Reply With Quote
Old 04-22-2017, 01:19 PM   #11
yoinkster
Right so I've figured this out and now that I re-read your messages, I can see you guys were telling me the right thing but it wasn't super explicit so I didn't pick up on it right away.
The actions I described were of delayed button pressing. So I'd single lock the car, walk away then an hour later, try to remote start it and it didn't work (and knowing what I know now, I now know why!).
It was the act of double locking it that made it work because ...... you need to push a button first to wake the car up before it'll remote start.
I had been just pushing the remote start expecting it to work but that module gets turned off once the car is left for some time. The act of pushing the lock button wakes up the relevant module so that it will accept a remote start signal. That's the explicit instruction I didn't quite catch. Wake the car up first, then she remote starts! Seems so simple now haha.
On the plus side, my remote start works every time now that I know how to operate it!
Old 04-23-2017, 07:21 AM   #12
102SS
waiting at the tree
102SS's Avatar
Glad you got it figured out.
Old 04-23-2017, 05:29 PM   #13
audiowhiz
audiowhiz's Avatar
Drives: 2005 Corvette M6
I had a similar problem once.
The remote start stopped working although I can hear the relay click and the lights flash, the car just does not start.
A mechanic friend said the battery has to be disconnected for 30 minutes to clear the BCM and try again.
It worked! Now the car starts every time I try.
BTW, you should not have to press the lock button twice for the remote start to work. Once is enough.
audiowhiz is offline   Reply With Quote
remote start, remote start stopped working
