Old 10-23-2009, 12:45 AM   #1
JewelZ
Just Lovin' My Camaro!
JewelZ's Avatar
Drives: CGM 2LT/RS/AUTO
Another Issue. Tire Monitor System!!!
So after the bluetooth music streaming issue, and window getting stuck than rolling itself back up after 10 minutes, yet another issue! My 'Tire Monitor System' service sign is showing. I kept getting tire pressure low messages in different tires for the past few days and finally decided to address the issue. The only reason I prolonged the refill of air is because the issue kept self resolving and the pressure would jump up and down all four tires. So while filling up air the system was detecting just fine. I filled all tires up to about 40psi so I could take air out on all of them slowly to be at accurately 36psi. After I finished filling I relearned the pressure, it just stayed at the learning screen. After about 10 minutes I got fed up and turned off my car. I started to drive home hoping it would relearn itself. I really didn't want to drive on so much pressure but I didn't want to let air out and find out I let too much out. I got home and relearned it and it showed me the error message 'Service Tire Monitor System'. Good thing all this happened before I could take it to the dealer for the other issues.
CGM( GRAY 2 tone interior ) 2LT/RS/AUTO
NJHKKM $29,965.00 1EH37 1100 03/28/2009 AFF, B34, DCP, FE9, GBV, LLT, MX0, SGC, UQA, WRS, 2LT
50 YEARS FROM NOW, DON'T YOU WANNA BE ABLE TO LOOK BACK AND SAY YOU HAD THE GUTS TO GET INTO THE CAR!?!?
ORDER STATUS : 6000 as of 08.18.2009. VIN# 33,985!!! His name is 'GOLIATH'!!!
GOT MY CAR!!!! AND I LOVE IT!!!!
JewelZ is offline   Reply With Quote
Old 10-23-2009, 11:25 AM   #2
pinkcamaro10
2G1FC1EV1A9110079
pinkcamaro10's Avatar
Drives: 2010 2LT/RS, 2013 2SS/RS 1LE
Send a message via MSN to pinkcamaro10
When you put air in your tires, it adjusts...
yeah if you read the manual, you don't just press relearn the system and it does it automatically, you have to press relearn wait til it honks, let the air out of the tire in a specific order until it honks again. or something to that effect.
So either read the manual and calibrate it yourself, or stop by the dealership and they will do it for you.
pinkcamaro10 is offline   Reply With Quote
Old 10-23-2009, 12:25 PM   #3
jspeak32
jspeak32's Avatar
Drives: Silverado
Correct. Once it honks, you let out the air in each tire in the following order:
Front left, front right, back right, back left. The horn will honk each time letting you know to go to the next tire. Roughly 10 seconds per tire, just wait for each honk.
jspeak32 is offline   Reply With Quote
Old 11-05-2009, 02:36 PM   #4
Rosanne Canfield
Drives: 2010 White Camaro 2SS
I wanted to send a quick note thanking you for the information regarding correcting the issues with the service tire monitoring system. I had the same issue and just recalibrated all my tires and the pressure reset on all 4 tires and the warning messages disappeared and everything is working great now. The correct PSI is showing in the DIC. It worked exactly as you said it would.
Thanks again!
Redhotrosie
Rosanne Canfield is offline   Reply With Quote
Old 11-11-2009, 10:07 AM   #5
rmpackers
Ride this Chevy
rmpackers's Avatar
Drives: 2010 RJT RS Camaro
I did this last night and it worked great! I didn't go in any particular order, but the horn blowing about scares the crap out of ya! These cars are scary smart!
NFL OWNR I love the smell of new car in the morning!
rmpackers is offline   Reply With Quote
Tire Sealant Kit - Warranty Issues jbreed Wheels and Tires Talk Sponsored by The Tire Rack 38 09-14-2011 03:18 PM
Accuracy of DIC's Tire Presssure Reading Abygale Wheels and Tires Talk Sponsored by The Tire Rack 24 11-20-2009 01:49 PM
500.00 per perelli tire not a myth! AVman Wheels and Tires Talk Sponsored by The Tire Rack 51 10-20-2009 04:45 PM
Tire Monitoring System issue Richochet83 Wheels and Tires Talk Sponsored by The Tire Rack 24 10-08-2009 10:55 AM
WHAT A NIGHTMARE!!! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 110 09-27-2009 12:25 PM
