Old 03-06-2017, 10:37 PM   #1
ZOOMSS
ZOOMSS's Avatar
Drives: 2010 Red Jewel 2SS/RS
Front Sway bar removal help
Ok, so the front sway bar on my SS got bent a little on the passenger side due to a road buckle I didn't see and I am currently trying to replace it along with doing the 1le upgrade as well. However I am at a standstill with the sway bar, no matter what I try I can't get it to feed through and out. It always seems to catch on the front of the subframe no matter how I try and wiggle it. What's the trick to getting it out besides a hacksaw or taking it to the dealership and paying to have the subframe dropped? I haven't been able to pry the bushings off of it either, they seem to be stuck on due to age and I can't get enough leverage to pry them off. I've been fighting with this damn thing for the better part of two days and am at my wit's end on it. Any help or tricks those of you who have done this in your garage would be most appreciated. I've replaced sway bars before on different cars but none have ever put up this much of a fight.
ZOOMSS is offline   Reply With Quote
Old 03-06-2017, 10:46 PM   #2
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
It's not an easy task but it can be done.
I went out the pass side. I was back & forth trying to get it twisted just right. If memory serves correctly, while pulling from the passenger side I twisted it counter clockwise. I also lifted the pass brake disk/knuckle assy. with a floor jack.
Also, be sure that the bar is between the bolts that hold it in, pass side.
Sent from my iPad using Tapatalk
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 03-06-2017, 11:37 PM   #3
Zombie killer
Emerald Coast Camaros
Zombie killer's Avatar
Drives: 2013 2SS/RS L99
Front sway removal
You may not want to hear this , but if you loosen bolts to the engine mounts and raise the engine up about an inch, the front sway will slide out the passenger side like butter. Especially if you have the electric steering rack, it's the only easy way. Trust me, I tried installing a new one and only got frustrated because it was so close but wouldn't go.
Zombie killer is offline   Reply With Quote
Old 03-06-2017, 11:49 PM   #4
Synner
Drives: cars
Take it out the passenger side, loosen the 2 motor mount bottom nuts, place a piece of wood under oil pan and lightly jack up. Comes right out with a little twisting and turning. Or if its bent then a sawzall and 20 seconds. But seeing how the old one comes out will help you route the new one in.
Old 03-09-2017, 04:57 PM   #5
OmniCamaro
US Veteran
OmniCamaro's Avatar
You get this done? I just installed my 1LE front bar, fun fun.
Old 03-10-2017, 10:21 AM   #6
mpsgolf
mpsgolf's Avatar
Drives: 2012 Camaro SS Transformer
Did you get it out and new one in?
Interested as sway bars are in my list to do ...
Mods: trunk subwoofer and amp, LED lighting (fogs, interior, trunk), skip shift eliminator, CAI cold air kit, Vmax ported throttle body, Stainless Works retro chambered cat back, JBA Cat4ward SS ceramic coated headers
Potential Next Mods: Tune, F&R sway bars, rear cradle bushing inserts and trailing arms
mpsgolf is offline   Reply With Quote
Old 03-10-2017, 01:27 PM   #7
OmniCamaro
US Veteran
OmniCamaro's Avatar
See my post above for removal.
Putting the new one in is just the opposite, in through the drivers side. I had to raise my vehicle pretty high up to get the new bar in. Not as bad as getting the old one out.
Old 03-10-2017, 01:42 PM   #8
naikaidriver
Drives: 2010 Camaro 2SS/RS
The most critical part of removing the front anti-roll bar is unbolting the motor mounts and lifting the engine a few inches. Once you do that, the removal is pretty easy.
I did mine with the car on jack-stands and using the 'ol block of wood under the engine lift technique. No problem.
Scott
"The Beast" 2010 Camaro SS/RS LS3
Diablo T1000 with Phastek custom tune, K&N Intake, Hurst Short-Throw Shifter, Flowmaster, Outlaw II Exhaust, BMR 1" Lowering Springs, BMR 3-way Adjustable Anti-Roll Bars, BMR End Links and Reinforcement Brackets, BMR Trailing Arms, ZL1 wheels, Nitto NT555 G2 Tires, Z28-style Rear Spoiler, Hawk Plus Brake Pads, Motul RBF600 Brake Fluid
naikaidriver is offline   Reply With Quote
Old 03-10-2017, 05:23 PM   #9
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
Yep I tried for a long time before loosening up the motor mounts.
justjoshin is offline   Reply With Quote
Old 03-11-2017, 11:02 AM   #10
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
I took mine out easily without lifting the engine. That does not need to be done. All you need to do is turn your wheels all the way to the right while the car is in the air and pull the sway bar out from the passenger side by twisting it. Patience and logic is your friend here. Also, getting the car high enough in the front helps too as you can dip the sway bar down a bit.
StlRomAniaN is offline   Reply With Quote
Old 03-11-2017, 03:38 PM   #11
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
+1
Getting the thicker 1LE bar in is also doable without lifting the engine and with the wheels all the way to the right, although it will appear impossible.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 03-11-2017, 03:41 PM   #12
StlRomAniaN
Originally Posted by wakespeak View Post
+1
Yup. Same with the solid JPSS 27mm front bar. It was actually easier than removing the stock bar.
Old 03-17-2017, 08:18 PM   #13
Dean
Union Brother
Drives: 2010 Camaro SS RS
I just installed the race/competition Hotchkis bars. They recommended jacking up motor and loosening the trans cross member brace. It worked!
I have a whipple on top which prevented me from finishing without dropping the back of the trans down a bit. You don't have to take the driveshaft off.
Dean is offline   Reply With Quote
Old 10-05-2021, 12:16 AM   #14
driftxtz
Drives: Synergy Green 2010 , 1969 Camaro RS
FYI. Do not need to jack up motor. Go thru passenger side. remove one splash shield cover pin and loosen one white cable cover then you have plenty of room.
driftxtz is offline   Reply With Quote
