Old 03-09-2017, 02:00 AM   #1
KermitSS
Drives: 2011 Camaro SS
Halo's on only
Hi everyone. I have searched and searched for the past few days through many threads, but I cannot seem to get an exact answer on this.
I have a 2011 SS/RS. When in the auto position, I would like the halos to be the only lights on. No side markers, no rear lights, no DRL fogs, nothing. Just the halos. If anyone could help me out with this it would be tremendiously appreciated!!!
KermitSS is offline   Reply With Quote
Old 03-09-2017, 08:21 AM   #2
KermitSS
I did. So you are saying on stock that if you clicked it over one, that only the halos turned on and no other lights did?
Old 03-09-2017, 10:42 AM   #3
KermitSS
Can you provide me with a link that says that? It is my understanding that not just on the Camaro, but on any car, when you turn the parking lights on, the side markers and rear lights also turn on. Has been for every car I've owned.
Old 03-09-2017, 10:50 AM   #4
KermitSS
I'm sorry camaro2ss/rs, but I do believe you are wrong. Here is straight from my owner's manual:
"(Parking lamps): Turns on parking lamps on togher with the following: Taillamps, sidemarker lamps, license plate lamps, Instrument panel lights."
And in my case, the halo's also.
Old 03-09-2017, 02:59 PM   #5
KermitSS
I'm sorry but I don't believe I have an aftermarket harness on my car if it is doing exactly what the owner's manual states.
Is there anyone else that could chime in on this? Thank you.
Old 03-09-2017, 03:48 PM   #6
cyberLS
cyberLS's Avatar
Drives: 2010 Cyber Grey LS
http://www.gen5diy.com/halo-harness/
cyberLS is offline   Reply With Quote
Old 03-09-2017, 03:50 PM   #7
KermitSS
Originally Posted by cyberLS View Post
Cyber, that harness is to have the DRL fogs AND the halos on. I don't want the DRL fogs on. Thank you for replying though.
Old 03-09-2017, 04:04 PM   #8
KermitSS
Originally Posted by Thawilster View Post
I see where you're coming from. Go to Gen5DIY.com and search for the "Halo Harness." The only thing is, after installed, you must turn off the auto light mode inside the cabin in order to ride with the halos (only) on. I've had it for about a year and it works perfectly. Don't know of a harness that will do the same with the auto mode engaged.
So if I understand you correctly, install the harness that allows the DRL fogs and halos to be on at the same time, but then click left for off and the halos will still be on while shutting off everything else?
Old 03-09-2017, 04:10 PM   #9
Thawilster
Thawilster's Avatar
Drives: 2011 Black 2SS/RS L99 Vert
I have that harness and it allows for halos only. However, you have to switch your lights from auto mode when you get in the car for this function.
C.A.I. intake, APEX scoop, VMAX ported TB, Solo Mach XC catback, BMR 1" drop.
Thawilster is offline   Reply With Quote
Old 03-09-2017, 04:13 PM   #10
KermitSS
From auto mode to parking lights? Sorry for asking questions, just making sure I make the right investment for what I want.
Old 03-09-2017, 04:17 PM   #11
Thawilster
Thawilster's Avatar
Tried to delete my initial post since someone posted the same but, yes, only the halos will be on after switching the dial left.
Old 03-09-2017, 04:17 PM   #12
KermitSS
Great, thank you for the information!
halo
