Old 03-10-2017, 02:21 PM   #1
deahl001
deahl001's Avatar
Drives: 2013 Chevrolet Camaro ZL1 CRT M6
Brake Caliper Bolts
I read somewhere that the brake caliper bolts should be replaced any time they are removed. I've never seen that on any other car I've worked on... Can anyone confirm/deny that based on GM documentation?
While I'm asking questions, anyone know the torque spec for those bolts?
2013 Camaro ZL1 - CRT M6 ECF
deahl001 is offline   Reply With Quote
Old 03-10-2017, 03:20 PM   #2
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
They are torque to yeild bolts so they are really only meant to be used once. I'm pretty sure that's how they are on most cars.
jayno20 is offline   Reply With Quote
Old 03-11-2017, 09:02 AM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
most people reuse them without incident...most dealers do not replace the caliper bolts. Surprisingly, it was mentioned that many dealerships don't replace head bolts either. I retorqued my caliper bolts without any problem, but I suppose we should do what GM suggests.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 03-11-2017, 09:05 AM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
There like $8 dollars....cheap insurance when messing with your brakes IMHO.
Mods:
Old 03-11-2017, 10:18 AM   #5
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
I've reused mine and the car has seen some pretty heavy breaking and some light track use. That being said, I should have replaced them technically.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 03-11-2017, 03:19 PM   #6
Blownfogger540
Blownfogger540's Avatar
Drives: 2013 ZL1 416
from over the years my experience is any bolt that has a 10.9 12.9 on the head can not be a one time use
as that's a metric grade rating
Blownfogger540 is offline   Reply With Quote
Old 03-12-2017, 11:25 AM   #7
E. Bryant
Gearhead
E. Bryant's Avatar
Drives: 2012 ZL1
As best as I can tell, these bolts are not "torque to yield". They are indeed "torque to angle", and according to my torque wrench, the factory torque process puts them right about at the recommended maximum torque for the bolt size and grade.
The bolts do have thread locker applied as supplied, and I suspect that this is the reason for the recommendation to replace them after each use.
If in doubt, follow the factory recommendations. This is not a place to be making half-ass assumptions just because some random dude on the internet did some arm-chair engineering "analysis".
2012 Chevrolet Camaro ZL1 M6 - JRE 650 RWHP kit, AFCO heat exchanger, JPSS V4 aero, Z28 wheels for the twisties and Weld big-n-littles for the dragstrip.
11.193@128.13 in 515' DA
E. Bryant is offline   Reply With Quote
Old 03-13-2017, 08:28 AM   #8
deahl001
deahl001's Avatar
For anyone curious, a GM tech found in the service information that these bolts should be replaced when removed. For such a low price, I'm going with that advice. Thanks for the input!
Part number 11570788 - Qty 4 - Torque 30 ft lbs + 90 degrees
Old 03-13-2017, 09:01 AM   #9
winterboy8
winterboy8's Avatar
Drives: 2015 ZL1 Blue Velvet Metallic
Not doubting anyone, but I work in aerospace and have never heard of a torque that was xx lbs plus xx degrees after reaching that initial number.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
winterboy8 is offline   Reply With Quote
Old 03-13-2017, 09:13 AM   #10
deahl001
deahl001's Avatar
It's common practice in cars. Specifically in motor work. When you are working on heads, you typically use that method. Also, the GM spec is below for the brakes on our cars.
Old 03-13-2017, 09:29 AM   #11
Russell James
Russell James's Avatar
Any bolt where the tq spec is given in degrees past a tq is a TTY bolt.
TTY is a more consistent tq when sealants, lubes, locking agents... are used. Those things can throw the tq reading way off, so to get a consistent clamp and bolt stretch you do it in degrees. The bold stretching will maintain a stronger clamp force.
It can only be done once though, the second stretch to that length will not have the same clamping force. It's been fatigued and will just keep stretching instead of clamping. If someone successfully re-used a TTY bolt, they probably didn't stretch it the second time and it is not tq'd properly.
At a drag strip near me there was a critical head injury, someone got hit by a harmonic balancer at the starting line. As the lawsuits were flying, one of the defendants had a failure analysis done. End result... a TTY balancer bolt had been reused and snapped. The shop that did the last motor refresh was in a world of hurt. Any time negligence is involved, it can become $$$$$$$ and even criminal.
If you see anyone re-using a TTY bolt, you are looking at an idiot. Harsh, but fact. They teach that sht in HS auto shop, let alone a tech degree, state certification tests....
Old 07-07-2019, 12:19 PM   #12
hammersfd
Drives: 2017 SS Convertible Fiftieth Anniv
Reviving a dead thread here, but are the rear bolts same as the fronts? I can only find listings for the front.
hammersfd is offline   Reply With Quote
Old 07-08-2019, 12:28 PM   #13
VRZL113
VRZL113's Avatar
Drives: 2013 VR ZL1, M6
They are not the same.
Rear caliper to knuckle bolts part# 11515781
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
VRZL113 is offline   Reply With Quote
Old 07-08-2019, 10:06 PM   #14
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
His tag says SS not ZL1, if that's the case its not the same brembo.
ZMEnow is offline   Reply With Quote
