Old 03-11-2017, 08:23 AM   #1
Mudgett
Mudgett's Avatar
Drives: 2013 SS/RS
New to Camaro5 , new problems arise.
Good morning all. New to Camaro 5. Been reading alot of posts so I figured I'd join and make contact with other Camaro folks. Cen-Cal area. Looking to shoot the breeze about 5thgens and meet local folks to find out about car shows and camaro specific events. I've had some minor lifter noise but this morning I got a God awful rattle. I already have an appointment with a dealer regarding the lifters, set for 3-16-17. Now I will have to add this rattle to the list. I suspect it's exhaust, but I'm concerned it might be the lifter (s) getting worse. Since it's a couple days until I go into the dealer, I will most deff be working on getting audio/video of the rattle. I have no mods. 2013 SS/RS. 32k miles. Very well maintained weekend cruiser. Still have factory drivetrain warranty and extended warranty has been purchased also. Anyway. Glad to get started on here and looking forward to chatting with many of you.
Mudgett is offline   Reply With Quote
Old 03-11-2017, 08:43 AM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
noise could be anything from a lifter going bad which is more likely to happen, too a L99 engine to a rockers trunnion failing, too the manual trans slaves bearing support melting because it is not a billet Monster replacement, too the ls3 style chain tensioner falling apart from being plastic and not the ls7/2 dog bone style . To avoid any damage carefully watch oil pressure if its from the engine.
A rattle could also just simply be a baffle shot having it spot welds fail inside the muffler which is noted to happen with the stock "trash can" exhaust...called that for looking like two smashed metal trash cans. And rattling heat shield along the drive shaft tunnel ...
Good Luck, look for the noise with a hose as a stephoscope if needed and tear the valve covers off if needed to inspect ,tow it don't let it eat a valve and bite the engine as that's spendy.
Minor typewriter chatter from a ls engine is normal BTW because of the high lifting roller lifters and the preload being in a range to when the engine warms the tolerances become tighter and thus less noise for many. L99 AFM lifters are more prone to fail if your auto.
Old 03-11-2017, 04:50 PM   #3
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Welcome to C5. Hope you get your problems fixed.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 03-12-2017, 03:43 AM   #4
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Welcome to the site as well...Glad that you had the foresight to purchase the extended warranty, as well as, having the remaining drive train warranty...You should come out ok...Hope they can find the problem and have you rolling soon...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 03-12-2017, 06:25 AM   #5
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Welcome and good luck. Hope it's not anything serious. As prior mentioned avoid driving it , if you do eye the oil pressure, and have it towed to the dealer. Post back when you find out.
camguynj is offline   Reply With Quote
Old 03-12-2017, 07:36 AM   #6
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Welcome and hope they find the issue quickly.
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 03-12-2017, 08:04 AM   #7
jrhagen
Banned
Drives: Camaro
What's the rarest 2013 SS Camaro?
Unmolested, congrats!
jrhagen is offline   Reply With Quote
Old 03-12-2017, 08:25 AM   #8
69 SS 350 5 Speed
69 SS 350 5 Speed's Avatar
Drives: 69 SS Camaro 2019 Corvette GS Vert.
You can look at the build numbers and get an idea from the color and options list but you can not get it down to a certain combination of options. You would have to extrapolate the options spread over the models to get anywhere close. And even then it is still a SWAG. The single most rare 13 Camaro is the Dusk Edition Convertible. 158 built.
There is a fine line between hobby and obsession and I think I crossed it!!
69 SS 350 5 Speed is offline   Reply With Quote
Old 03-12-2017, 08:53 AM   #9
jrhagen
Banned
Drives: Camaro
You completely missed the point.
Old 03-12-2017, 10:25 AM   #10
Mudgett
Mudgett's Avatar
Drives: 2013 SS/RS
It's an L99A6. Wanted the M6 but the ole lady insisted on auto in case she has to drive me in an emergency. So auto it is. She has not, nor will she ever set foot behind the wheel, but the emergency situation is a valid point. So auto it is.
The rattle ended up being a shredded ac belt. Changed that using a few zip ties. Went ahead and changed the serp too.
Used a pvc pipe to check engine noise. Either a slightly noisy lifter or a Very noisy injector. I'm betting lifter.
Old 03-12-2017, 10:30 AM   #11
Mudgett
Mudgett's Avatar
Drives: 2013 SS/RS
Thanks. Been in the auto industry for many years. Engine machinist for a decade. Restored all types of cars over the years. I've found that the unmolested cars are the ones worth the most after 30+ years. I have plans for a few exterior, interior, and performance mods, but nothing that can't be changed back. Performance mods will not commenced until all warranties have expired. By then, I'll probably have changed my mind and continue to leave stock.
Old 03-12-2017, 11:19 AM   #12
Mudgett
Mudgett's Avatar
Drives: 2013 SS/RS
Dude was just saying it's rare that ppl don't mod their cars. Wasn't a true statement of "rareness" but I do appreciate you chiming in. All replys are welcome as long as they aren't degrading, rude, or obscene.
I thought there were only 69 COPOS made in '13. Not 100% on that tho.
Concerning mine, it's just 1 of 18k SS's made that year, and I just want to keep it clean / running good for many years to come.
Old 03-12-2017, 12:13 PM   #13
snarky
ultracrepidarianism
snarky's Avatar
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport
Hope it is just an exhaust leak. I like yellow.
snarky is offline   Reply With Quote
Old 03-12-2017, 02:01 PM   #14
18LTLoveIt
18LTLoveIt's Avatar
Drives: 2018 Hyper Blue LT RS
Welcome aboard. In here a stock 5th Gen look is rare.
And that's cool, makes ours more unique!
18LTLoveIt is offline   Reply With Quote
