03-12-2017, 06:28 PM | #1 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
CTS-V Upgrade
I'm thinking of getting the CTS-V upgrade this year and I've got some questions.
1. How easy are the 6-piston pads to change out? 2. What pad set up is good for Auto-X? 3. What pad set up is good for Track? Thanks
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
03-12-2017, 11:31 PM | #2 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
The CTS-V setup is the same as the ZL1's and
1. Front pads are pulled out from the top of caliper after the 2 pins, center bolt, and spring is removed, easy just like the SS rear Brembo. 2. OEM 3. OEM
Swift....Silent....Deadly
03-13-2017, 01:17 AM | #3 | |
So the OEM pads hold up to track heat? But then again, I suppose that the 6-piston setup will generate way heat than the SS Brembos.
03-13-2017, 09:22 AM | #4 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
For Autocross OEM pads would work great. For road course track work I would highly recommend getting a set of track pads like Hawk DRC70's, Raybestos ST-47, or I know there are Carbotech's that a lot of people like too.
I did a track weekend with 6-piston fronts and OEM pads at Road America last year and although I never had any major braking issues ( as in no brakes left ) I did experience the beginning of pad fade and they also started "smearing" on the rotor which started producing pedal vibrations when braking. This was on a cool weekend (40-50's for high temps) and I have the Z/28 brake ducts installed as well. I then tried Hawk DTC70's for my next track event and was very impressed by the additional braking bite with the track pads and I did not experience pad fade with them. Also braking stayed smooth and had no vibrations afterwards. So I would highly recommend a set of track pads for big track stuff and for Autocross the OEM pads will work great.
