Old 03-13-2017, 03:12 PM   #1
Fusionofideas
Drives: 2015 Z28, C7 Corvette, Evo X
Z28 swap for Racing Brake Forged Calipers with Sintered Brake Pads and Carbon Ceramic
So I have officially made the switch from the OEM Brembo Calipers and Brembo pads to the Racing Brake Forged two piece calipers for the Carbon Ceramic Rotors. In addition we are using and testing their sintered metallic brake pad. The claim is that with the sintered metallic pad that it will actually cure the fractures that occur on the Carbon Ceramic Rotors and increase overall life of the rotor. I started with just the sintered metallic pads and ran two track days and noticed a significant difference in the overall appearance of the Carbon Ceramic Rotors. Additionally the braking power or brake Bite was significantly different from the OEM pad. We started with keeping the Brembo Calipers and running the Racing Brake Sintered metallic pads. I felt close to a 50% stronger braking capability.
The CC Rotors are ogiginal from the factory and have a full season of 35+ hours of track use and so this will be the perfect test for the sintered pad to determine the claim of using the pad to cure the CC Rotor and actually adding life and usability of the rotor. Included are before and after pictures and you can see that the racing brake sintered pads actually did in fact cure the fractures in the CC Rotor and effectively resurfaced the rotor. I also have gone through and cleared all the vents of debris and powder so coming into our next event we should see even better performance.
I will be posting images of the Calipers and also performance difference from our event in April at Buttonwillow.
Fusionofideas is offline   Reply With Quote
Old 03-13-2017, 03:22 PM   #2
Fusionofideas
Racing Brake 2 piece Forged Calipers
Ok so we have replaced the OEM Brembo Calipers with Racingbrake.com 2 piece Forged Calipers. Included are images. I will have more to report on overall braking power and difference in April once we run them in Buttonwillow with the NASA race. For now we just have the esthetics of the brilliant red which looks fantastic compared with the grey Z28. The performance is obviously the main interest.
The Racing Brake Calipers is made from forged 6061-T6 aluminum. As many of you know the Stock calipers - aluminum (Brembo) are mass-produced and are usually made through a casting or extrusion process which is not as dense and strong in structure as forging. The Piston Materia is Made of stainless steel instead of aluminum. The dust seal is built-in type (instead of external boot type) uniquely designed to shield the dust and foreign material from contamination and will not rip - as commonly seen on boot type dust seals. So for now enjoy the pics and soon I will post up actual performance.
I have run Buttonwillow many times for many years so I am excited to see the difference in braking capabilities as well as being able to get a longer life out of my Carbon Ceramics. Look for updates coming soon.
Old 03-13-2017, 03:26 PM   #3
aris
Drives: Z/28
What inspired the desire to swap calipers? didn't think the OEM calipers left much on the table in terms of performance.
aris is offline   Reply With Quote
Old 03-13-2017, 03:30 PM   #4
Fusionofideas
The Racing Brake Calipers are two piece forged so they are lighter, also offer better performance with stainless steel pistons as well as maintaince abilities. I will be posting up performance gains as we test on track.
Also, they are red....and red is cool
Old 03-13-2017, 03:51 PM   #5
DemonZL1
199
DemonZL1's Avatar
Drives: like a granny
I think the calipers are L/R backwards. Bleeder needs to be on the top.
2024 Silverado ZR2 LZ0 Duramax
2021 Shock SS 1LE A10
www.youtube.com/@demonworksmotorsports
Anderson composites coupon code : Demon
DemonZL1 is offline   Reply With Quote
Old 03-13-2017, 03:59 PM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Old 03-13-2017, 03:59 PM   #7
Fusionofideas
Your right and good eye for seeing that. That was just for the pic. I have not got pics of them installed on car yet. I'll update today. Thanks
Old 03-13-2017, 09:46 PM   #8
Fusionofideas
Pics added.
Old 03-14-2017, 03:11 AM   #9
Chris93Si
Drives: 2015 Z28
Very cool update, I'm enjoying following your braking journey
Chris93Si is offline   Reply With Quote
Old 03-14-2017, 10:00 AM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Their probably 90 gazillion dollars though.
Orange Krush II
Old 03-14-2017, 10:24 AM   #11
JusticePete
Drives: Camaro Justice
The braking in factory form on the Z is quite good. Why not just change pads?
Old 03-14-2017, 01:03 PM   #12
hjdca
hjdca's Avatar
Drives: 2015 Z/28 Black
I believe he said the logic is that these new pads do not "splinter" the CC rotor and you are supposed to get more life out of the rotor with these pads. The pictures are showing a more smooth rotor after the new pad use, while the original OEM pad photos show a more splintered rotor.
2015 Black Z/28
70 Chevelle SS396
01 M3, 88 Land Cruiser
hjdca is offline   Reply With Quote
Old 03-14-2017, 01:20 PM   #13
frenchsquared
frenchsquared's Avatar
Drives: 15 Z28, 01 Corvette, 96 Corvette
That would imply the pads wont work on the current calipers. Otherwise JusticPete's question still stands.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
frenchsquared is offline   Reply With Quote
Old 03-14-2017, 01:43 PM   #14
JusticePete
As I understand it, these are the same brakes used on the Enzo so why change calipers?
We have our Z/28 clients on G-LOC pads. They are reasonably priced and easier on the rotors.
